New to me 3820 Branson
   / New to me 3820 Branson #1
Sawman10
Moreland, GA
Branson 3820i
Hi all and thanks for the welcome.
I picked up the tractor on Saturday but I haven't received the manual yet (hopefully get it this weekend).
I am going to do a complete maintenance on it before I start using it and need guidance as to everything I need to change and recommended fluids.
The tractor is a 2007 (345 hours) with a BL20a FEL and 5 foot Kodiak Cutter. I know the previous owner and know that the blades have never been removed. I tried to remove them yesterday and they will not budge. I had cheater bars and a torque multiplier and had over 1200 pounds on it. I will be doing regular maintenance on it so I plan to cut off and replace with new bolts and anti seize for future ease.
The paint is faded but no other issues.
   / New to me 3820 Branson #2
If you have access to a torch, heat the nuts cherry red and shock cool them with water....they'll screw right off.
   / New to me 3820 Branson #3
If you don't have a torch big enough a 50/50 mix of acetone and ATF is the best penetrating oil around... soak them several times offer a day or two and it should make a big difference for you.
Good luck
I have had them soaking but still wouldn't move. I cut them off with a grinder today and found both with the key stripped off. I will install new ones with anti seize.
   / New to me 3820 Branson #5
Are they reverse threads? My King Kutter has reverse threads. I remember one time when I was wiring a house, I accidentally had the polarity reversed. When I flipped the switch, it burned darkness, lol. I guess that was funnier in my head.
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
48 PIECE HEAVYEQUIPMENT KEY SETS (A53843)
48 PIECE...
2016 Case IH True Tandem 345 (A50123)
2016 Case IH True...
100 GAL FUEL TANK W/PUMP TOOLBOX COMBO (A53843)
100 GAL FUEL TANK...
2023 EAST TEXAS 40FT GOOSENECK TRAILER (A53426)
2023 EAST TEXAS...
20 ft Angle Boom (A53117)
20 ft Angle Boom...
