new to me 03 century 2535
   / new to me 03 century 2535 #1
wilkija
Killeen Texas
Century 2535
Hello All,
I just picked up this tractor a few weeks ago for $4,000. parked it and have since been going through it. I was shocked to see a century brand hydraulic filter still on it! I have been using this site a lot to help find cross reference filters and fluids, So thanks a lot for that!
Things done so far:
-changed all fluids and filter. (the WIX hydraulic filter 51202 doesn't seem to fit right, leaks a little at the bottom and was hard to seat all the way. I think I am going to have to try a Napa one.)
-changed water pump gasket due to leak.
-new belt
-new coolant because of gasket.
-new glow plugs
-left side loader hydraulic lift cylinder leaking so got it rebuilt.
-new air filter
To Do:
-Left side tank is leaking diesel at seam. previous owner did a patch job but it's failed. have plastic welding kit ready after I run it really low on fuel.
-need to take entire exhaust apart and replace gaskets and retorque.
other than these things, it drives and shifts really smooth. even though it only had about 5 gallons of fluid in the tranny when I drained it. but no whine or weird noises, so that's good.
If anyone knows a good/maybe more comfortable seat that would swap right out for the current one do please let me know. one easy to get at tractor supply or the likes. thanks.
   / new to me 03 century 2535 #2
Wilkija, I have the 2004 model of the same tractor and loader combo with ag tires. and almost 1700 hours on it. I religiously use the Kukje filters to avoid any issues. Even today the engine uses no oil between changes. Glow plugs, and other misc items do wear out, but it is a tough tractor that has done a lot of work. I do use the 5W-40 T6 Rotella and find the tractor is very smooth running with it, better than the 15w-40. The seat you have is not the original, it looks like a Tractor supply seat. The steel plate is not on the original. The original seat was lousy on mine and the replacement Tractor Supply one is not much better. I think Kukje has installed better seats on the later models. The c-50 loader was made by Humpolec in Chzech republic and is one of the toughest loaders I have ever seen or used. It does have the Euro style quick connect and that is way stronger than a skid steer quick connect. But that limits options for other attachments. At one time adapter plates were made.
At any rate, you have a good solid tractor that should provide years of service. W.Jones
Thanks 52,
I was surprised to see the loader cylinders use snap rings to hold it all together. New one for me but the seals are seals so easy enough to get sourced and changed. One problem i have is they ran the loader hydraulic supply right behind the exhaust in the little opening at the bottom. It has a small rub/melt spot on the line. Im shocked after almost 20 years it hasn’t burned through. Gonna cut the hole wider and put some heat wrap on that part of exhaust. Is yours routed that way too? Kinda hard to see but the black hose in the circled area photo.
   / new to me 03 century 2535 #4
$4k? That seems, to me anyhow, a real solid price!
Ya it was! I practically stole it for sure. Even came with the brush cutter and hay spear. I don’t think the previous owner was mechanically inclined. The water pump was leaking. I saw rtv around the outer edge of the pump. But when i removed it there was a gasket on it that had zero rtv on it just around it lol. Not sure what he was thinking there.
   / new to me 03 century 2535 #6
Welcome to TBN and congratulations on a great find. I am glad to see it get a good home. I am sure it will give you many more years of great service.
I have a project Branson I am working on myself. Unfortunately work and other things have put it on the back burner for now but hope to get back on it soon. If you find a good seat let us know. I need one for that tractor as well.
will do! I was hoping to find a spring or strut dampened seat for it but haven’t really looked yet.
   / new to me 03 century 2535 #8
I was assuming you got sidetracked on that project. Hope you find the time to get it rolling again.
   / new to me 03 century 2535 #9
just a few friendly words of advice on that unit, first please use the OEM hydraulic filters even if every other filter you use is aftermarket, the oem filter have a rather large bypass in the bottom that if not present can cause significate damage to the hydraulic systems, your front end loader the c-50 long, you will not be able to get parts for this from any branson dealer( trust me i have tried many times) they just aren't available through branson, your engine is rock solid if serviced properly it will outlast the chassis in most cases. the clutches are a different story however, the build quality on those were hit or miss when they were new, if your is still reacting to your pedal strongly good, if not you will probably have to replace or reman it.( city brake & clutch in Oklahoma city are champs at remanning these) grease the ever living crap out of that tractor i dont know why those models go through so much grease but they do and you will want to keep some handy for this reason, if this unit ever needs a tie rod end, and it hasnt already had the upgrade then know its expensive the original tie rods are no longer available, and you will have to do the upgrade kit to get it repaired, thats about as much as i can think of but if i remember anything else i will update this for you.
And welcome to the family!
Thanks asteral, i haven’t seen too many greese fitting except on the loader. If you can give me the locations i will grease them all this week. If not I'm sure i can walk around it and find them. Since the water pump was leaking I’m already scared that it overheated and possibly caused damage. I haven’t started it back up since i put a new gasket on it. My property is an hour from me so i only go out there once a week. I put the gasket with a thin layer of rtv last week, torqued and left to dry. Gonna fill and start her up Thursday. When i test drove it though, The clutch feels great as far as i can tell. The tractor only has 650 hours on it.
10x16.5 Tire Assembly (A53472)
10x16.5 Tire...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
Rhino FM72 Finishing Mower (A51573)
Rhino FM72...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
