New to Grid Tied Home Solar...
   / New to Grid Tied Home Solar...
Will the solar self limit when it can't send surplus to the grid?
Maybe the generator will slo to eco mode if solar providing.
I had asked the same question and never did find out except was told I needed a battery bank to make it all play nice.
   / New to Grid Tied Home Solar... #172
So the grid tied solar would still produce if it sees what it thinks it "line" voltage. I guess that's pretty obvious to some, but seems pretty clever to me.
Yes but where does the excess go if not able to go to grid... sending to generator thinking it's grid can't be a good thing.
   / New to Grid Tied Home Solar... #174
A grid tie system needs to be able to disconnect from the grid and form its own "microgrid" if the grid goes down if you want to be able to keep using your own power. Utilities these days don't allow interconnection without automated disconnecting if the grid goes down, because they don't want to have power on a line they think is down.
A microgrid needs a sufficient source of power to handle transient loads; typically this is done with battery storage & PV, though it can be done with a (constantly running) generator. I assume you could do it with a generator + PV and no batteries, but that generator needs to be running in case there's not enough juice coming from the PV for peak loads (like your A/C starting up, which can easily pull 100A for a short period).
A lot of people were caught unawares during last year's PSPS in California when they had no power despite having lots of PV.
   / New to Grid Tied Home Solar... #175
I don't know the answers to these questions but will be sure to ask when the electrician comes to hook up the gen. set. One thing the utility guy did say was that with my sized gen. I wouldn't be able to handle A.C.,electric oven, or dryer. It certainly seems to me that the power needs someplace to go like a battery system when usage is low and production is high, which is most of the time for us. Even in that situation where does the power go if batteries are charged and usage doesn't keep up with out put from p.v.. In the conversation he mentioned either a gen. or battery system and I told him I couldn't afford a battery system and didn't think they were a good investment yet and he agreed saying he just used a portable gen..
It's interesting but there is still a lot to learn.
   / New to Grid Tied Home Solar... #176
Microgrids, I wonder what the pros and cons are for the large energy producers. I'm guessing that will have the largest effect of whether that technology gets adopted.
   / New to Grid Tied Home Solar... #178
I'm beginning to believe there was some misunderstanding between myself and the utility guy I was talking to. I thought it was too good to be true at the time and believe even more so after reading more on the subject. It sure would be nice though.
I am going to go ahead with having my generator set up just in case. I do believe this will become more common here even though this is just the 2nd time we have had our power shut off and by far the longest at 18 hours.
   / New to Grid Tied Home Solar... #179
Im an electrician, but have next to no knowledge on off grid and grid tied systems. All i know is my sister fell for scam install years ago, she basically saves nothing after utility adds on utility line use charges. I maintain some generators for off grid homes, and thats the jist of my experiences. When off grid, grid tied, power walls, etc started to come online, i was just winding down my career, and didnt want to add to my knowledge base.
I would think needing to run a generator to allow power use from solar seems kinda nuts. What am i missing. If your needing to run a generator, why use solar
   / New to Grid Tied Home Solar... #180
Seems that most home solar systems exist solely to cut power bills VS generating your own power in an outage.
My take on it is that the solar back-spins your meter backwards when it's producing more power than you're immediately using. When you need more than it can produce, it takes power from the grid and your meter spins forward.
If there's a power outage, it shuts down your solar system to prevent back-feeding power to the grid.
If you had batteries, your solar system could stay on and charge the batteries and you could have power during an outage.
You can't pull power directly from a solar system to, say, your refrigerator. It needs to go through an inverter. Morning, evening, clouds, rain, etc... would make it highly unlikely that you could regularly draw power directly form the solar system, that's why you need batteries or the grid to act as a source.
As to having a generator, it wouldn't make sense to run a generator so that your solar system could come on and not put out anything, since your running the generator.... that whole part doesn't make sense to me at all.
As I see it, if I did get a solar system, it would not only be capable of reducing my electric bill, but it would also be capable of powering my home in a power outage, which means the additional costs of batteries and probably a generator.
I guess I'm thinking more off-grid than most typical installations.
Komatsu PC220LC Excavator (A59814)
Komatsu PC220LC...
1998 PRATT ISO DROP FRAME TRAILER (A59575)
1998 PRATT ISO...
Pickup Instructions (A55272)
Pickup...
Stateline SJ-100 3 Phase Generator (A57148)
Stateline SJ-100 3...
2017 RAM 2500 (A58214)
Mini Skid-Steer Steel Mounting Plate (New/Unused) (A59225)
Mini Skid-Steer...
