New to forums--what type/wt oil Ford 3000?
   / New to forums--what type/wt oil Ford 3000? #1
Jsf973
Missouri
1971 Ford 3000
Just got a Ford 3000 gas tractor last month. Learning as I go. Need to order a few manuals I think. What oil would be the best for winter, or should I use the same as for hot weather? What would be the best hydraulic fluid to use? The oil filter is new, so I don't think it needs to be changed yet? Thanks in advance, Kate
   / New to forums--what type/wt oil Ford 3000? #2
SAE 5w-20 below 14 degree F up to 40.
SAE 10w-30 or 20w for 40 degree to 90 degree
Hope this helps
Thank you very much Mike.
   / New to forums--what type/wt oil Ford 3000? #4
i'd be real carefull about running 20w oil on a machine that could be 47ys old. i'd put a mechanical oil gauge intot he sender port and see what my pressures were.
if in arctic weather.. I bet a 5w30 oil .. even syn.. might be great. 5w40 syn diesel oil even better...
remember.. the oil recs in the owners manual are from 65 :)
   / New to forums--what type/wt oil Ford 3000? #5
I personally like Rotella T Synthetic 5w/40. You can get it cheap at Wal Mart in gallon jugs. I've standardized on it for all my cars and equipment - it is a great diesel oil, and an even better oil for gasoline engines (diesel oils need to work a lot harder than the typical gasoline oils, so they have a much more robust additive package).
   / New to forums--what type/wt oil Ford 3000? #6
i'm runnoing valvoline ultra blue 5w40 in my diesel pickups now.. i love it.
2014 Chevrolet Express Cargo Van (A50323)
2014 Chevrolet...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
2008 UTILITY REEFER TRAILER (A51222)
2008 UTILITY...
19010 (A48082)
19010 (A48082)
2010 MQ POWER 25KW GENERATOR (A50854)
2010 MQ POWER 25KW...
2019 Ford F-550 XL Crew Cab Forestry Chipper Truck (A49461)
2019 Ford F-550 XL...
