New tires, or new tractor?
   / New tires, or new tractor? #1
beardley
Cato NY
NH Boomer 30
Fine folks of TBN, I have been debating a few options, so I'm looking for some opinions. I currently have a 2012 NH Boomer 30 shuttle shift, Loaded R1s, FEL, 5' brush hog, tiller, box blade, pallet forks, and a 6' rear mount blower. I used this tractor extensively while I built my house, and its size was invaluable for moving timbers, and grading the new lawn. I'm at a point now though, that it actually causes me a fair amount of trouble ever year, because I spend 1/2 of the summer fixing the ruts in the lawn. I bought it w/ ag tires, because at the time I did a lot of firewood work, so the extra traction in the woods was a big help pulling logs. I've been buying firewood as of late, and its so cheap around here that it just doesn't make sense to still cut all of my own. So my main use cases are:
-Brush hogging less than 1 acre, plus roughly 1 mile of trails.
-Moving Firewood from the shed to the house
-snowblowing in the winter
-occasional gravel driveway work
-garden plot work with the tiller and the bucket
I have about 2 months I can drive the thing on the lawn without making a mess, and the rest of the time, I'm just creating work for myself in the spring, so the question is, should I look at some R4s w/o loading the rears, or should I be looking at a smaller unit. Say a B or BX? I hate to try and rebuild by implement supply at this point, so I would love to be able to stick to the 5' toys, even if I need to reduce my ground speed with the brush hog. I know a BX or a 1 series wouldn't handle the 5', but I'm just not sure where I should be heading here. . .
   / New tires, or new tractor? #2
Just my thoughts, but some R3 Turf tires probably would do exactly what you need. Make wide turns, try not to tear the grass. Avoid the grass after a rainstorm. You will be just fine. Don't load the tires. In fact running at 5psi under recommended inflation, will never leave ruts on any lawn. Also, turf tires also function very good during plowing and snowblowing operations. Messicks has a utube video on how successful turf tires can be in the wintertime.
I have R4 industrial tires on my tractor. Good for loader work. Then we did a 1400 feet of gravel road, and the gravel delivery guy also helped with gravel spreading. His tractor used R3 turf tires....because he also does sod delivery and laying down the sod, using that same tractor and loader. He must not leave any ruts. R3 tires did great in the gravel.
Even a BX can tear up the grass and leave ruts on the lawn, if your not careful. It is certainly a lighter tractor, but smaller tires go with it, so the lbs/sq-inch is no different than your NH.
   / New tires, or new tractor? #3
Change the tires and leave out the extra weight from filling them. Leave it in 2 wheel drive when possible can also help. As already pointed out smaller tires on smaller tractor may not gain much.
Thanks for the quick responses. I assume the Turfs would require a different rim size as well right? The R1s are pretty narrow. I could always grab a set of chains as well for the turfs if traction in the woods or my few low spots become problematic.
   / New tires, or new tractor? #5
None of the uses you list mention the lawn. When do you drive it on the lawn? If you're mowing the lawn with it, I'd suggest a riding lawn mower of some kind for the lawn. It'll cost less than new wheels and tires for the tractor, and mow better.
Brush hogging a mile of trails seems like it'd be a lot of work with a sub compact tractor, and I'm guessing that a 6' snow blower is a good thing to have in NY.
   / New tires, or new tractor? #6
Yes. Going from R1(narrow) to either R3/R4 does require new rims. They can be found on eBay or ordered from your dealer, or some other source. I am thinking $1200 to $1400 for all four tires, rims included.
To be honest, only 8% of compact tractors sold are ordered with the R1 Ag tires. They are not as popular due to serious ruts and tearing of the ground. Never heard of R3/R4 tire owners complain about traction issues.
I'm not currently mowing the lawn with the tractor, I have a typical rider for that job. The damage is coming from just general movement around the yard, moving firewood, transporting mulch, etc.
The snowblower is a must around here. We typically see an average of 150" of snow per year, and my drive way is roughly 75 yards with a slope.
I'll have to swing into my dealer, and see what the cost would be. If we're talking less than $2000, then there is zero reason for me to consider a smaller unit, and the added cost associated with the upgrade. Its been a good tractor, I've only had 1 issue with the loader control valve in 8 years.
   / New tires, or new tractor? #9
   / New tires, or new tractor? #10
You often can find decent used tires mounted on rims at dealers. I don't know why, perhaps because you aren't the only person who decides that he wants a different platform?
2013 New Holland T4.75 Tractor (A52384)
2013 New Holland...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
GOODYEAR SET OF 9.5-24 AG TIRES (NEW) (A52748)
GOODYEAR SET OF...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
