New TC40DA Ordered
   / New TC40DA Ordered #1
BlueToy1
Central Illinois
Kubota MX6000
I ordered a TC40DA today & I've read on here that each brand has its own minor problems. To those of you with tc's from a new owner (arrives next week), what quirks do i need to keep an eye out for? I guess of what I've read, the battery leak seems to make me shudder tha most.
   / New TC40DA Ordered #2
I have 200 hours on mine and have had no issues. Took a little while to get used to the hydostatic but so far the tractor is great.
Relax and Enjoy
   / New TC40DA Ordered #3
I had the hydraulic fluid radiator crack at the hose connection. I saw a discussion here of this problem some time ago.
I could be wrong, but I believe they've since changed the radiator design to correct this problem.
Overall, it's been a good tractor.
   / New TC40DA Ordered #4
We did the Optima battery gig at about 50 hours. What a mess battery acid makes. /forums/images/graemlins/frown.gif
I should have just put the Optima battery in when the tractor was delivered new.
   / New TC40DA Ordered #5
</font><font color="blue" class="small">( what quirks do i need to keep an eye out for? )</font>
About the most notorious issue the widespread Boomer seat problem. When mine was delivered, my rear end stuck to the seat several times, and before I knew it, I had 100 hours on it!
Congratulations. I don't think you'll regret it for 1 minute.
Getting the 16LA loader?
Thanks fo the replies, has the battery issue been fixed by New Holland?
Yep, getting
16la w/ hd qa bucket
758C back hoe w/ 18" bucket
6' bush hog
Bush hog 72" med duty box blade
2 ton dump wagon
canopy
3 remotes
block heater
arm rests
I was looking at the ccm top & tilt but my better half put the brakes on that for now...I've spent plenty allready!!
I hadn't heard of a seat problem, but I think the Mrs must of. She's asked if she'll ever see me after I get it. I got to come back for fuel sometime!!
Now if I could only sleep at night.
   / New TC40DA Ordered #7
<font color="blue"> Thanks fo the replies, has the battery issue been fixed by New Holland? </font>
Well according to my dealer the problem was rectified even before I took delivery of our 40D. He told me that before I had to replace the battery. /forums/images/graemlins/frown.gif
Maybe someone that has a DA model can jump in here with a bit more info on the battery issue.
   / New TC40DA Ordered #8
My TC40DA has 60hrs and no sign of any battery issues. The battery fluid is filled to the top which is overfilled in my view. However, no leakage occured. There is a overflow tube that may be the fix to the problem. I mowed on 30 degree slow up and down all the times.
I don't think Optima 34 battery would fit in TC40DA. The length of the battery is 9" while Group 34 would be 10". A group 34 battery would sit on top of the mounting bolts. I think group 35 would be a better fit.
   / New TC40DA Ordered #9
I would be interested in hearing how the TC40 handles the 6' Bush Hog once you get using it. Maybe someone who sees this already is using this combo.
   / New TC40DA Ordered #10
<font color="blue"> My TC40DA has 60hrs and no sign of any battery issues. The battery fluid is filled to the top which is overfilled in my view. However, no leakage occured. </font>
That is about the same comment that I made at 50 hours, no obvious damage. I was then informed that the battery needed to be pulled out for a closer look-see. I followed those instructions and found one heck of a mess, you may want to do the same.
John Deere 946 Center Pivot Rotary Mower-Conditioner (A51039)
John Deere 946...
2014 KENWORTH W900 MID-ROOF SLEEPER (A50854)
2014 KENWORTH W900...
2011 MACK GU713 DAYCAB (INOPERABLE) (A50854)
2011 MACK GU713...
WEATHERFORD MP-10 TRIPLEX MUD PUMP POWERED BY A CATERPILLAR 3412 ENGINE (A50854)
WEATHERFORD MP-10...
vergenes (A50657)
vergenes (A50657)
2011 GMC Acadia SLE SUV (A50324)
2011 GMC Acadia...
