New T 4.75 50hr Service
   / New T 4.75 50hr Service #1
Jackfr
Plymouth, MA
NH WorkMaster 33 Ford F5000 NH T 4.90 Ford 2110 JD555B
We finally pulled the trigger and purchased a new T 4.75 about a month ago. We traded the 2013 Boomer 3050 CVT. Thank God the 3050cvt is gone!!
The T 4.75 with industrial tires, hydraulic power shuttle, 3 rear remotes, 3rd function remote up front and MSL loader is great, I can't say enough good things about it. Only three issues I'm having; figuring out an easy way to remove the oil filter (Utopia did you figure it out), getting use to the MSL loader, it works different then any other one I have and getting enough ballast on the back of the tractor to counter act the loader. We have both rear tires loaded with rim guard and 210 lbs of wheel weights on each rear wheel and still when using the loader if your not careful you can lift the rear end off the ground. Anyone have any suggestions?
On another note I cannot find in the owners manual anything about changing the oil/oil filter after the first 50 hrs only the hydraulic filter and fuel filters and if you go by the rest of the schedule you won't need to change the oil/oil filter for 600 hrs. I plan on changing it now at 50 hrs anyway. What did you end up doing Utopia?
   / New T 4.75 50hr Service #2
The normal when using a loader is to have a heavy concrete weight hanging in the 3pt, it will all so reduce the load on your front axle and that's important.
ROME AH-240 LOT NUMBER 130 (A53084)
ROME AH-240 LOT...
2012 KENWORTH T370 PROPANE TRANSPORTATION TRUCK (A52472)
2012 KENWORTH T370...
48 PIECE HEAVYEQUIPMENT KEY SETS (A52472)
48 PIECE...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
2020 FORD F-250 SUPER DUTY (A52472)
2020 FORD F-250...
