New T 4.75 50hr Service
   / New T 4.75 50hr Service #1
Jackfr
Plymouth, MA
NH WorkMaster 33 Ford F5000 NH T 4.90 Ford 2110 JD555B
We finally pulled the trigger and purchased a new T 4.75 about a month ago. We traded the 2013 Boomer 3050 CVT. Thank God the 3050cvt is gone!!
The T 4.75 with industrial tires, hydraulic power shuttle, 3 rear remotes, 3rd function remote up front and MSL loader is great, I can't say enough good things about it. Only three issues I'm having; figuring out an easy way to remove the oil filter (Utopia did you figure it out), getting use to the MSL loader, it works different then any other one I have and getting enough ballast on the back of the tractor to counter act the loader. We have both rear tires loaded with rim guard and 210 lbs of wheel weights on each rear wheel and still when using the loader if your not careful you can lift the rear end off the ground. Anyone have any suggestions?
On another note I cannot find in the owners manual anything about changing the oil/oil filter after the first 50 hrs only the hydraulic filter and fuel filters and if you go by the rest of the schedule you won't need to change the oil/oil filter for 600 hrs. I plan on changing it now at 50 hrs anyway. What did you end up doing Utopia?
   / New T 4.75 50hr Service #2
The normal when using a loader is to have a heavy concrete weight hanging in the 3pt, it will all so reduce the load on your front axle and that's important.
2005 CATERPILLAR D3G LGP CRAWLER DOZER (A51246)
2005 CATERPILLAR...
2009 Caterpillar 279C High Flow Compact Track Loader Skid Steer (A51691)
2009 Caterpillar...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2012 Honda Pilot SUV (A51694)
2012 Honda Pilot...
378740 (A51572)
378740 (A51572)
2020 PETERBILT 567 TRIAXLE (INOPERABLE) (A52472)
2020 PETERBILT 567...
