New storage tank
   / New storage tank #1
tractorski
southern Vermont
Branson 3510
I just purchased a 300 gallon storage tank for off road diesel. It has been used for that purpose previously. There is a few gallons of residual fuel in the bottom, but I am unsure of its condition. My plan is to drain the residual crap out, but what should I do after that? I got it for $300, which includes the 110 electric pump, hose and handle. The previous owner could not get the drain plug out and rounded off the nut. What are my options?
Sent from my iPad using TractorByNet
   / New storage tank #2
You can try to drill it out and then use a large easy out to back out the plug.
Just make sure that you drill as large a hole as possible to allow the plug to give.
What size is the drain plug?
   / New storage tank #3
You could turn it upside down to drain it but I agree that getting the old plug out is the right way to start. I would also flush the tank out while you have it empty, there is no telling what crude is in there.
I also suggest putting a good filter (water and particulate) on your setup.
   / New storage tank #4
I might be crazy but I'd lock a pair of vice grips on it super tight, then whisper a little heat around the edges and see if the plug doesn't come right out before I drilled it..
   / New storage tank #6
Is the plug made of steel?
You could always tack weld a nut or something to the plug.
I would not go anywhere near a fuel tank with a welding outfit!!!!!:eek: YMMV
Remember, his goal is to get it drained out!
   / New storage tank #7
They make damaged bolt removal sockets, Sears has them, they are like an inverted screw extractor. I have used these on many bolts, nuts and pipe plugs.
Dave
   / New storage tank #8
I'd replace the drain plug with a brass one in order to avoid hving this problem again in the future.[/B]
   / New storage tank #9
This is a Diesel tank, not a gas tank. It is far less explosive, but it can burn quite well. If you do choose to weld on it, make sure all holes and caps are uncovered, so there is nothing to build up pressure.
The bolt extractors sounds like a good idea.
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A50323)
2006 GMC C8500...
2014 Chevrolet Cruze Sedan (A50324)
2014 Chevrolet...
ATTENTION! PLEASE READ (A50120)
ATTENTION! PLEASE...
