new starter came in
   / new starter came in #1
TOMMYHPX4X4
schriever, louisiana terrebonne parrish
gator hpx 4x4
this new starter is better than the stock one that was on the hpx.. why because this one works .lol it looks identical to the stock one but this one is made in china??? i guess i'll see how long it last.even if it last 2 years it would still be cheaper to buy another one instead of popping out almost 500.00 for one from deere. it took 2/3 days to come in they don't waist time on their shipping .
   / new starter came in #2
keep you old pinion and clutch. We have had an issue with the cheaper starters with the pinions getting stuck in the flywheel. Just check it before you install. You may be ok just check it.
   / new starter came in #3
Used to know a young China lady, she worked just fine .....
Long as it serves the purpose, use it !!!!!!!!!!!!!!!!!!!!!!!!
:cool:
" Made in China " don't mean it will not work >>>>>>>>
works just fine so far . i done cranked it over atleast 15 times maybe more. i use it all the time with alot of stop and gun drivin. hopefullt it will last a while.
2015 Toyota Prius Hybrid Sedan (A56859)
2015 Toyota Prius...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
2019 John Deere 1025R 24HP 4WD Loader Utility Tractor (A55973)
2019 John Deere...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
Toyota 7FGU35 8,000lb. Propane Forklift (A55973)
Toyota 7FGU35...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
