New Shop Lights?
   / New Shop Lights? #1
monteu
Bronze Member
NE Kansas
Kioti DK5010
I am wiring my 30' x 40' shop. The sidewalls are 14 ft. high. Any recommendations on what kind of lights I should put in? I really don't have any ideas. Is there like some kind of online lighting planner where you enter your dimensions and it tells you how far apart to space your light fixtures? I will be doing machine work in here. The ceiling will be white metal. Any ideas will be appreciated. Thanks
   / New Shop Lights? #2
Where do you live? How cold does your shop get? To me you put up as much light as you can afford, generally the flourescent tubes are the most cost effective and keep a good color range, but there are other alternatives.
   / New Shop Lights?
NE Kansas. Temp range is -0 F degree to 100+F.
   / New Shop Lights? #4
4 foot T-8 fixtures. Make sure they are cold start. Menards has these on sale periodically and they work great. Install a network of outlets on the ceiling, perhaps two or three rows with outlets every 8 feet in your case. You can then move the lights around or add extra ones where you need them. In your case, I would start with about 3 rows, each with 4 fixtures. That's about 0.5 watt fluorescent per square foot. That's what I have in my pole barn and it's fine but I'm adding an extra set to double that just over the workbenches. Try it and then you can add extra lights where you find they would be good for working.
   / New Shop Lights? #5
Do to goverment restrictions the 4ft fluorescents are no longer made.
   / New Shop Lights?
The lights I have seen at Menards are plugin. Is that what you are suggesting just put in electrical outlets?
   / New Shop Lights? #7
If you have a Home depot, go look at their display. The HO(High Output) tubes are the way to go, I put 4 pairs in my 30x36 basement and they are very bright. For a shop I would add two more pair.
   / New Shop Lights? #9
Like Wedge40, I have the HD 6 light HO fixtures in my 30x40 and they do a great job. I am going to add more as the money allows.
   / New Shop Lights? #10
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A52377)
2021 Ver-Mac...
UNUSED LANDHONOR 11' X 19' ALL-STEEL CARPORT (A54757)
UNUSED LANDHONOR...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A54757)
UNUSED WOLVERINE...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2025 GIYI SGB20 20in Single Cylinder Stump Grapple Bucket Skid Steer Attachment (A53421)
2025 GIYI SGB20...
