New Shop build Plywood wall finishing ideas needed.
   / New Shop build Plywood wall finishing ideas needed. #11
If you use intumescent paint do the walls swell if you rub up against them? Asking for a friend.
Eric
In a barn or shop? Gee, paint and live with it.
Yah, if I was in da the UP that’s what I would do! However, down here in “Troll Land” , my OCD prevents me from doing the practical thing! Ha ha
   / New Shop build Plywood wall finishing ideas needed. #13
   / New Shop build Plywood wall finishing ideas needed. #15
I was thinking - all that $$$$ spent on a new barn. I would be looking for some type of fire retardant or fire resistant paint.
Yes - I would calk the seams and nail holes. Who knows - keep going and you might end up with a duplex rental unit.
Or my “home away from home” when my wife kicks me out of the house!
   / New Shop build Plywood wall finishing ideas needed. #17
That 3/4 inch ply will make some fine walls! Looks like you used rock wool for the insulation?
I had to buy a gallon of the "I" paint to put on a 2' x 6' drop down attic stairway cover in my garage to pass fire code. First time I had ever heard of it.
It was about a year ago and IIRC it was around $125 per gallon from Benji Moore. I wouldn't recommend using it unless you really have to for code.
I only used about a cup of it...
But we got the CO which is all that mattered!
   / New Shop build Plywood wall finishing ideas needed. #18
You entertaining royalty? I wouldn’t bother to caulk. Great looking building by the way.
   / New Shop build Plywood wall finishing ideas needed. #19
I would use screws instead of nails. I personally don't see the need to caulk or hide the screw holes. They don't bother me, and I like to know where the studs are so I can build shelves in the future. I do like white paint on the walls to brighten everything up, but also to contrast what I have on the walls, or shelves.
If I was to caulk, I would use Big Stretch caulking. I've been using it on jobs for clients for awhile now and it's worth the extra money.
If I was to fill the holes from the screws, I would use joint compound. It sticks to everything, and it's super easy to sand smooth.
If you prime with Zinsser 123 before painting, you will use a lot less paint and have a better finish.
I only use two brands of paint. Valspar from Lowes. Duramax is an exterior paint that is really, really good. I use it on interiors all the time if I thing I need a better quality paint the Interior paint. It's also great on bathroom walls where moisture and mold is an issue. The other paints that I buy are from Sherwin Williams. They cost more money, but my clients all feel better when I use it on their homes. Emerald is by far the very best of the best paints out there. Nothing comes close to what it does!!!!
   / New Shop build Plywood wall finishing ideas needed. #20
Plywood and paint
2019 KOMATSU WA380-8 WHEEL LOADER (A51246)
2019 KOMATSU...
8ft Perforated Metal (A51573)
8ft Perforated...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A52576)
2015 KENWORTH T370...
