New Shop build Plywood wall finishing ideas needed.
   / New Shop build Plywood wall finishing ideas needed. #1
turbo36
Michigan
JD X739 AWS (3), 2016 Toolcat, JD 2038R
Planning on using sanded 3/4" plywood for the first 8 feet of the interior walls of my new barn build. I am uncertain as to how to finish the walls, I plan on painting them white but not sure whether I should try to caulk the seams and nail holes or just live with them?
   / New Shop build Plywood wall finishing ideas needed. #2
If it was me I would caulk. It would not take too long and would probably give a better finish. When you paint things white cracks always stand out because cracks are black. The caulk would at least bridge that gap and hide the cracks. Still would not be drywall perfect but it is a barn and will look better than 95% of barns out there.
   / New Shop build Plywood wall finishing ideas needed. #3
This is what my plywood walls that I'm working on look like. No caulk. I build 2x4 stud Faux? walls on 24" centers and used 1/2" plywood. Took a ton of paint. Did 2 coats of Kilz and 3 coats of interior semi-gloss paint.
   / New Shop build Plywood wall finishing ideas needed. #5
3/4" plywood? Wow! $! Anyway, I caulked (latex) my OSB before painting. I needed three coats of latex paint to cover the printing on the OSB since it bled through.
   / New Shop build Plywood wall finishing ideas needed. #6
3/4 would be nice to attach things to. Can we ask what you are paying for it there? I worked in a shop for years that had roofing tin walls. Nice for fires but you couldn't attach nothing to it.
   / New Shop build Plywood wall finishing ideas needed. #7
Prime then caulk the obvious flaws and apply the finished coat. If you have big exposed knots you may want to fill and smooth them with drywall mud. You only build it once but you will look at forever.
I bought 53 sheets of 3/4" inch sanded birch plywood for 50 bucks a sheet from a lumber liquidator. They are perfect condition.
   / New Shop build Plywood wall finishing ideas needed. #9
Consider caulking and using intumescent paint (yes it's not cheap, no it's not 100% fireproof, yes it does help).
“Intumescent” I can’t wait to work that into a conversation. 😅 Just when you think you know everything someone more educated than you throws out something for you to look up on Google. Thanks for the info!
2015 Ford F-550 Auto Crane 4004EH 4,000LB 2 Ton Crane Service Truck (A51692)
2015 Ford F-550...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51692)
2012 Trail-Eze...
UNUSED CHERY INDUSTRIAL 14' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
2013 Ford F-150 4x4 Pickup Truck, VIN # 1FTFW1EFXDFB07930 (A51572)
2013 Ford F-150...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
