new shell rotella????
   / new shell rotella???? #1
whitearrow
philadelphia,ms
john deere 5203
hello all.i was wondering how the new shell rotella 15w-40 would do in my gas powered kohler engine?i have been using castrol gtx 10w-30 in it for about 7 years.i was just wondering if the new rotella was even rated for use in gas powered engines.
thanks,
whitearrow->>>--------------->
   / new shell rotella???? #2
You can use Rotella in gas or diesel engines, and you'd only be giving up a little bit on the cold-start flow capabilities. In general, diesel oils are better at keeping impurities at bay so I use them in all my vehicles and engines.
   / new shell rotella???? #3
thanks,
The Rotella triple 15W-40 is rated SM-SL for gas engines so as long as your engine is rated for the viscosity no problems. I believe SM is the latest API rating designator.
   / new shell rotella???? #4
SM is the latest rating. I doubt a Kohler engine requires the current rating anyway. Why switch to a different brand and higher viscosity? Unless you're having issues with oil consumption, or are using it in the arabian desert, I think you would be better staying with the current viscosity. Brand pref is up to you and ultimately not that critical.
   / new shell rotella???? #5
thanks,
For THAT engine...stick with the 10W-30 Castrol.
i guess i just wanted to see how it performed in a much cheaper engine before i put it in my way more expensive atv or diesel tractor.i have been getting a very slight engine clicking,for lack of a better word, on first startup.after it gets warmed up the clicking goes away.i just thought that the rotella might protect better that all.
thanks for all the thoughts,
whitearrow->>>------------->
   / new shell rotella???? #7
How old is your Kohler? You might want to try some Marvel Mystery Oil in the oil and/or gas. Suppose to clean up the valves/lifters when used in the oil..... lots of people seem to swear by it on some other lawn/garden tractor groups.
Small gas engines usually use straight 30wt or that multi weight you are using. But try a little Marvel in the crank case.
   / new shell rotella???? #8
Marvel Mystery Oil
My Dad was one of those "use MMO all the time guys", so I am too. Dunno if it makes a difference or not :confused: but, if he said to use it, that's what I do. :rolleyes:
I think I read somewhere, maybe in here, that it's just a mix of ATF/kerosene or something? Smells neat, tho.... :D
Manac Walking Floor Trailer (A50322)
Manac Walking...
2008 Ford F-550 4x4 Dump Truck with Lift Gate (A53422)
2008 Ford F-550...
23013 (A53421)
23013 (A53421)
23018 (A53424)
23018 (A53424)
2015 CHEVROLET C3500 SERVICE TRUCK (A51406)
2015 CHEVROLET...
2025 Swict 66in Bucket Skid Steer Attachment (A53421)
2025 Swict 66in...
