New set of Pallet forks for the B2650.
   / New set of Pallet forks for the B2650. #1
Porchfan
Oak Ridge, NC
2013 Kubota B2650 HSD, 2020 BX2380, JD LX-277 lawn tractor 2000
Picked up a set of light duty (2200lb) 42inch pallet forks from Everything Attachments. Here's the link to the pallet forks: Small Compact Tractor and Mini Skid Steer Pallet ForksTheir facility is only an hour from where I live so I drove over their and they loaded me up. These forks weigh only 238 pounds. After a week of use and can honestly say these things are awesome. I should have bought these a year ago. What a productiviy enhancer. THis week I used it mostly to pick up logs, stumps and lumber after having my local sawer come out to the property and mill a few poplars, ash and oaks. Check the size of the butt of this poplar (36-38 inches, Estimated weight ~ 800 lbs) IMG_4266.jpg.
   / New set of Pallet forks for the B2650. #2
Looks great. I've been scrounging material to build a set of forks and a boom pole for the 3 point. (i don't have a FEL) I already have many uses in mind.
I like the way you're "testing" it by holding it over your chainsaw. :)
lol... Yeah I guess I did put the saw under the forks. Would have been pretty bad if that butt had dropped.
I was careful to keep it low when I moved it to our log pile. On the three point, you will probably have more lift capacity than with a FEL.
I like it on the front. Easy to see and operate. You just need to be careful to balance the load evenly and run it low and slow
   / New set of Pallet forks for the B2650. #4
My tractor is a little smaller than yours, but yes, I think lifting capacity should be pretty good. I keep about 300 lb of ballast on the front and can add more when needed. My rear-mounted finish mower weighs 800 lb, and it handles it like a dream with the ballast. Without the ballast, the front tires do more sliding than steering when the mower is lifted.
I would love to have a FEL, but I'm not feeling the extra $ to add one right now... I can do what I need with the 3 point -- just not as conveniently.
Congrats on the new toy. Looks great.
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2010 GMC Seirra 1500 4x4 Crew Cab Pickup Truck (A55973)
2010 GMC Seirra...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
2014 VOLVO VNL (A55745)
2014 VOLVO VNL...
CHALLENGER MT 525B TRACTOR (A58214)
CHALLENGER MT 525B...
