New seals for hydraulic cylinder.
   / New seals for hydraulic cylinder. #1
tcreeley
Elite Member
Hudson, Maine
2003 NH TC30
I have a mini Northstar Trencherman backhoe that I picked up 20+ some years ago from what was then Northern Hydraulics. (Modified since from 5 hp to 8hp and 1.2 gpm pump to 11 gpm 2 stage pump- faster)
Lent it to a friend and it came back with a screwed up cylinder. I ordered a couple seal kits- couldn't figure out how to do it- so got a new cylinder. The seal kit has been hanging around 18-19 years. I've borrowed an o ring or two. But I was digging a culvert trench a few days ago when the dipper cylinder started shooting fluid. In a rush I looked online and called Northern Tool- After forever- they informed me the backhoe was discontinued in 2002. I asked them to check some numbers on a seal kit I managed to find and they matched. It has 2"bore, 1" shaft, 12 stroke welded cylinder by Prince. They said they would call back about an alternative cylinder. (haven't yet)
2 days ago on TBN I found a manual for a Bradco backhoe whose cylinders looked mighty similar. It had a nice section on replacing seals- and removing the gland ring. I broke down and bought a spanner wrench ($36) with 1/4" pins- adjustable to up to 3 ". With that I was able to coax out the square rod so I could pull the shaft out. That's where I got stuck last time.
The leather backing seals to an O ring were gone. The major shaft seal was crumbling. I got them in- replace 2 shaft seals and 2 back up leather washers. I didn't have enough for anything else. I got it all back together and back on the backhoe- and it didn't leak! I still have to work on the 8 hp engine- wants to stumble when the backhoe is tipped. I had 10w30 in it and it was spitting oil out by the air intake filter. I switched to 30 wt and have less oil spitting. I have to play with the choke and governor to keep it going- then it steadies. I hate small engines- but it still keeps going. The bucket wobbles because the bearing surfaces are so worn. Next year I;ll get it welded.
Feels good knowing I can rebuild the cylinders when I need to...just need to find a place to order the seal kits reliably. I try to do it all from home. This is the spanner I bout- Armstrong 3" adjustable, 1/4 " pins. You could always make one I suppose.View attachment 277941
This is the manual I used from TBN.
I found a way to smooth the engine on my mini backhoe out (tecumseh 8hp)- I took some oil out of the motor. When I checked it, it was just at the top edge and over a 16th on the full mark. I kept thinking about it- how it would stumble when it was tipped. Now the oil line is 1/2 way up the cross hatch fill mark. It ran great today as I finished digging the trench for the 20' culvert. But I do dislike those press fit grease zerks- they come out easily. I have needle tips for the grease gun to use for when I lose one. There were some massive brown shale rocks that I split, broke up, and went around.. Culvert is in and gravel on top. Soon I need to dig a sloping drainage ditch running along my roadway and leading to the culvert. The other side is done.
   / New seals for hydraulic cylinder. #3
tc,
Is this slop in the pins ?
Here are some pics of my greasy old mini backhoe, and the end of the 20' culvert I stuck in. I do everything myself on a limited budget. I had my well dug, septic put in. I never have hired anybody and so I am always learning as I go. Could be better the 2nd and 3rd time around, but the first is always interesting.
Welding- I do farm out- the backhoe frame was done 3 years ago. Yesterday an end cap on the square steel tubing fell off. The pins are all pretty good on the bucket- the bearing surfaces are shot that the pins go through. The horizontal pin at the base of the boom cylinder starts to work a slight bend over time. Once a summer it lets go and cracks in the middle. I have a piece of cold rolled steel the right diameter that I cut a piece off of. I drill out holes for cotter pins- and all is good. My motor and pump are pushing the limit on this mini backhoe- designed for 5 hp and 1.2 gpm. (using 11gpm/2 stage and 8hp). Always amazes me how much power such a small unit can generate.
View attachment 278142View attachment 278143View attachment 278144
   / New seals for hydraulic cylinder. #7
How do I install a new power steering cylinder in a mahindra 3525?
I've never seen a Mahindra in person. You probably can get some good info in the Mahindra forums. There are a good many very knowledgeable people.
Goodluck.
2012 BMW 328i Coupe (A51694)
2012 BMW 328i...
2020 Terex RL4 Towable Light Tower (A51691)
2020 Terex RL4...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2016 CATERPILLAR 308E2 CR EXCAVATOR (A51246)
2016 CATERPILLAR...
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
