New rear remotes on MF1643
   / New rear remotes on MF1643 #1
jtheise4
SE Michigan
Massey Ferguson 1643 & Allis-Chalmers D14
Finally got a set of rear remotes added to my MF1643. Only regret is that I didn't get them installed from the start.
   / New rear remotes on MF1643 #2
Good move-what are you planning on doing with them?
   / New rear remotes on MF1643 #3
If I'm seeing correctly....... please replce those cast iron plumbing Tees with the proper hydraulic fittings. They are not made to withstand hydraulic pressure.
Aside from that...... nice install.
I have a Bobcat grapple on order.
The install was completed by the dealership, so I'm going to trust that he knows what he's doing. I know my Timberwolf log splitter uses cast iron plumbing also.
   / New rear remotes on MF1643 #6
Right, but only on the return line to the tank. Not knocking your dealer, but pipe fittings are generally rated for 150 psi, and your tractor's hydraulic pump probably puts out 2500 psi.
I like that the lines are split so both rears and third function on the loader are available without having to plug, or unplug extra lines. Handy. :thumbsup:
I appreciate the comment. I'll certainly be checking with him. I don't want a blow out!!!!!
2015 VOLVO ECR88D (A50854)
2015 VOLVO ECR88D...
IH Farmall 504 Tractor (A50514)
IH Farmall 504...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
