Mowing new rear finish mower
   / new rear finish mower #1
89cummins174
Bucks, Pa
Kubota BX24
Well i bit the bullet and got a rear finish mower for a good price. i am happy with the cut that i got out of it but i only have one problem with it. When i engage the rear PTO it snaps the mower right on and jerked the tractor a little bit. Is there a easier way to engage the PTO so i don't get the whiplash effect? Is that going to hurt my tractor over time, I engage the PTO at a idle (1350 rpm) or should the rpms be higher?
Thanks in advance Shawn
   / new rear finish mower #2
Which tractor? I engage at low rpm and then throttle up. I can feather the clutch for a smooth engagement on my 2800, but you may have a different set up.
   / new rear finish mower #3
The PTO lever should engage with no resistance. If you feel resistance back off the PTO lever and let out on the clutch. You may have to do this a couple a couple of times (sometimes). Mine will jerk too if it is forced. This isn't good for the PTO gears and isn't doing the mower belt a lot good either.
I have a BX24 and I think that it has a electronic PTO i am not sure b/c I don't know if i can feather it on or not. Does anyone with a bx24 MMM do the same thing?
No I don't have a clutch peddle I have a lever that i slide down and lock in. It takes 3 seconds then the pto engages and jerks the tractor.
   / new rear finish mower #7
I apologize. I don't know about BX's. LeRoy Brown does. Maybe he can help.
   / new rear finish mower #8
First of all props to you for recognizing that abrupt deck whiplash could be a problem. I suppose it could shear a pin or break a U joint on the PTO drive shaft.
Did you try to engage the PTO at a lower RPM? Also keep the deck a little higher so it not starting up and cutting grass at the same time.
Our 3PH has turnbuckles that adjust and lock down any side to side movement of equipment...does yours? If so once you mount up the equipment and hook up the chains drive forward and lift it up. After sliding the deck or brush hog left and right try and tighten the turnbuckles up at the same time so the deck is more or less 'squared up'...that should help limit and side 2 side movement.
   / new rear finish mower #9
I have a BX24 and what from my dealer told me, its a wet clutch for pto. What I do is have rpms down to 1600-1900 and then slide the lever down until there is an inch before it has to slide all the way down and over. I would hold it in there and then it would engage slower then slapping it into pto on. It allows the pto to start moving a bit before engaging in full rpm pto speed. Once the PTO starts moving, I would slide it all the way down then to lock position. Then up the engine RPM to the pto rated speed. This is how I do it without the engine feeling like it buckling under the PTO being slapped on and no black smoke. Nice and easy does it. :)
OH OK so it is a wet clutch. I tried to slide it slow but i didn't find the sweet spot yet. I know i have had the bota for a couple of years but have not needed to mow with it yet i guess thats why i came straight to TBN when this rfm jerked my tractor around.
2020 FOR TRANSIT CONECT CARGO VAN (A52577)
2020 FOR TRANSIT...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2019 Ford F-150 XL (A50120)
2019 Ford F-150 XL...
2007 Peterbilt 335 Mickey AO-A Battery Truck (A50323)
2007 Peterbilt 335...
PT Conveyor (A50121)
