New PTO generator and 3pt carrier
   / New PTO generator and 3pt carrier #1
bubbacuse77
Platinum Member
Wisconsin
John Deere 3520, John Deere X749
I bought the Genny last year and made most of the carrier last year but waited a year to paint it. I have finally learned to not be to quick to paint because I often want to modify things after I try them out. Genny is Voltmaster 12k. image.jpgimage.jpgimage.jpgimage.jpg
   / New PTO generator and 3pt carrier #2
Nice setup. How many KW?
   / New PTO generator and 3pt carrier #3
Did the gearbox come with the generator, or was it sourced independently?
12 KW and yes the gear box came with the Genny.
   / New PTO generator and 3pt carrier #5
Great Job !! :) Really Like Your statement about " Being To Quick to paint " . I learned that awhile back also and like you , I usually wait 1 to 2 years before painting as like you say " A modification " seems to always pop up .
Fred H.
   / New PTO generator and 3pt carrier #6
nice job on the unit, I like your wheels to move it around when not on the tractor, and your PTO shaft storage,
I just wire brush off the burnt areas (welded areas) where the modifications took place and repaint, I like things looking some what professional when there "completed" there is usually a few weeks in there that testing is taking place, tho,
the thing is unless one spends mega dollars for paint it all looks weathered in a year or so any way, and I prefer weather faded paint over a rust bucket, look,
Thanks for the kind words fellas.
   / New PTO generator and 3pt carrier #8
WOW.. IM jealous.. Im sorta, kinda want a PTO generator.. Primarily to run the well pump or water heater, i have dual EU2000 Hondas for the smaller stuff..
What make/brand is it? Where did you get it?
   / New PTO generator and 3pt carrier #9
Nice setup. I especially like the foot on your third leg. Bolt plate off a leaf spring pack, isn't it? I've recycled several for just that purpose. :D
You are correct sir.
I believe I got the Genny from Electricgeneratorsdirect.com. I needed a bit of power since I heat and cool with a 5 ton ground source heat pump. The 12 KW will run the heat pump and just about anything else I want, including the electric stove.
2003 Peterbilt 330 T/A Progress A90LS 4,500 Gallon Fuel Truck (A51692)
2003 Peterbilt 330...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2025 K0311 UNUSED Galvalume Corrugated Steel Panel (A53117)
2025 K0311 UNUSED...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
2011 BMW 328xi AWD Sedan (A51694)
2011 BMW 328xi AWD...
