New PT-425 owner
   / New PT-425 owner #11
And there's slots in the top of the hood forward of the fan... and the gas tank looks different. Gas tank, battery, muffler wrap, engine air cleaner, in that order? Silver valve covers. Lug tires. Didnt' opt for the arm rests....
Needs a spinner knob! And fuzzy dice... :laughing:
   / New PT-425 owner #13
My New PT-425, "Artie" Arrived on Tuesday. It was a bit of an adventure as the delivery truck couldn't get closer than 6 miles from my home because of new road paving. (They said the 75' semi trailer was too heavy for fresh asphalt) Fortunately I was able to track down a forklift and my neighbors small trailer.
Here's Artie.
I'm really impressed at how much more robust this tractor is than my old Yanmar tractor.
I'm sure I'll have lots of questions down the road.
First, how do I add a picture to my profile?
Cheers,
Steve
Congratulations... Looks like your tractor has a smile on it's face too! :D
   / New PT-425 owner #16
Also, in 10 years you can go back and see how sparkling clean the machine once was! :laughing:
ANd then you can occasionally post one of the original pictures of your machine, pretending that it is in spotless condition after a decade, sort of like Mossroad does occasionally... :D
   / New PT-425 owner
Thanks everyone,
I really put Artie through his paces today. I picked up a 20’ log in the “jaws” of the 4-in1 bucket and held it up while I chainsawed from either end. Then I moved a big mound of dirt. I had the rear wheels pop off the ground a couple of times but otherwise he performed exemplary.
The engine is a Subaru. The exhaust comes out on the right (drivers) side. I’ll post. Pictures of the engine compartment later.
Cheers, Steve
I’m sorry but I dont’ have internet access at home so it sometimes takes a couple of days to respond.
   / New PT-425 owner #19
Why its as clean as the day I bought it...
   / New PT-425 owner #20
I had the rear wheels pop off the ground a couple of times but otherwise he performed exemplary. .
We on TBN refer to that as "The PT Pucker"....
On an articulated machine such as these, the center of gravity changes significantly as you turn. As you turn the steering wheel either direction from straight forward, the machine gets shorter and the center of gravity shifts to the side you are turning towards.
For fun, put on a loader bucket and lift it 3-4 inches off the ground.
Turn the steeering wheel all the way to the right.
Set the parking brake and get off the machine.
Start throwing stones, boulders, bricks, pavers, etc.. into the bucket until all of a sudden, the bucket sits on the ground and the left rear wheel comes off the ground.
Take the last item tossed into the bucket out and watch it sit down again and the bucket rise.
Then put it back in again so the left rear comes off the ground again.
Go sit on the tractor and see if it makes the left rear come down. If not, turn the steering wheel towards straight.... the left rear will go down. Turn right and it'll come off the ground again.
Pretty fun.
I think it should be required reading and hands-on practice for everyone to understand about the center of gravity on these things....
and then keep it in mind as you operate the FEL every time. It'll remind you about lifting a full bucket too high on even the slightest slope and what can happen quickly. Keep it in your mental toolbox. :thumbsup:
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
2000 FORD F-650 SUPER DUTY (A58214)
2000 FORD F-650...
2014 Jacobsen AR3 3-Deck Commercial Rotary Mower (A56857)
2014 Jacobsen AR3...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
Honda Pioneer SXS700 4X4 Utility Cart (A55787)
Honda Pioneer...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
