new PT-425 Hydraulic Filters ???????
   / new PT-425 Hydraulic Filters ??????? #21
The hydraulic filter on my 1445 is a Gresen k22001, 10 micron.
   / new PT-425 Hydraulic Filters ??????? #22
You wrote:
</font><font color="blue" class="small">( If the robin engine filter is the same as the older ONAN's (opposed twin) then you can use the motorcraft FL-400S, Fram TG3600 or Purilator Pure One 20195. I have found these filter to be much better than stock Onan. They have three times the filtration area and finer filtration. )</font>
For owners of PT425 with the steel tank (Kohler engine) these would be the correct filters also, BUT they are too long with the engine as it is installed in my PT. Didn't feel like pulling the motor (the filter would fit, but can't be removed or replaced) or cutting a hole in the side, so I found the equivalent alternative shorter ones. Will post that number when I replace the filter next.
Mark H.
   / new PT-425 Hydraulic Filters ??????? #23
these are filters that interchange pt, fram p1653a,motorcraft fl162,wix 51551,purolator h32010,ac delco pf16. maybe this will help you /forums/images/graemlins/laugh.gif
   / new PT-425 Hydraulic Filters ??????? #24
Found this out...Wix filter available on Amazon.com for 10.95...cross referenced at wixfilters.com for a gresen k22001
Part Number: 51551
UPC Number: 765809515512
Principal Application: Various Hydraulic Applications (10 Micron)
All Applications
Style: Spin-On Hydraulic Filter
Service: Hydraulic
Type: Full Flow
Media: Paper
Height: 5.209
Outer Diameter Top: 3.663
Outer Diameter Bottom: Closed
Thread Size: 1-12
By-Pass Valve Setting-PSI: None
Beta Ratio: 2/20=6/19
Burst Pressure-PSI: 380
Max Flow Rate: 12-16 GPM
Nominal Micro Rating: 10
Gasket Diameters
Number O.D. I.D. Thk.
Attached 1 2.729 2.415 0.255
   / new PT-425 Hydraulic Filters ??????? #25
I have been using Fleetguard HF7608 on my 422
   / new PT-425 Hydraulic Filters ??????? #26
FOR THOSE LOOKING FOR REPLACEMENT FILTERS FOR THE 425 HYDRAULICS I SUGGEST THAT THEY TRY 'ORIGINAL EQUIPMENT HEADQUARTERS,
www.oehq.com.
I just found DELCO PF16 at $4.80 each and their shipping was also much less than next lowest vendor ($6.10 each).
(4) ELECTRIC MOTORS (A54757)
(4) ELECTRIC...
2020 DRAGON ESP...
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A57193)
UNUSED LANDHONOR...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
Case 950 8 Row Air Planter (A55315)
Case 950 8 Row Air...
2017 Ford F350 (A55973)
2017 Ford F350...
