New PT-180 owner
   / New PT-180 owner #41
Are you talking about a cooling fan for the engine compartment, or a radiator and fan for the hydraulic fluid, or both? Either one is simple to do if you have good mechanical skills. You must consider the amount of amps available to work with.
   / New PT-180 owner
I have good mechanical skills. I have a 25 year background in repairing and rebuilding mailing equipment. Lots of cams, bearings, motors, pumps and then some.
When it comes to engines, and such I've worked on my cars mostly old school stuff. These day's I just take it to a shop. So it will be touch and go until I learn the in's and outs of the PT.
I was talking about just a cooling fan for the engine compartment for now. I know it will be pretty close with 4-35 watt lights and a fan. I may hook up separate switches so every thing is not all on at the same time.
   / New PT-180 owner #43
Despite Terry's recommendation, I'd suggest that you don't need to "fill the tank, run it, drain and refill the tank". That's a waste of money for the second refill of synthetic.
I've used synthetic exclusively for 30 years. You will get the full benefit of the synthetic even if there is some dino oil mixed in with it. Drain and refill the first time only.
Phil
   / New PT-180 owner
I agree seems like over kill. I'm sure he meant well. Now Amsoil or Mobil-1?? I know both are good.
Synthetic grease high speed grease. I just had to go buy another tractor to maintain. /forums/images/graemlins/smirk.gif
   / New PT-180 owner #45
Phil, I agree the flush could get real expensive. At each filter change you will get more and more synthetic. Just drain what's in there and then refill.
Bob Rip
   / New PT-180 owner #46
</font><font color="blue" class="small">( Now Amsoil or Mobil-1?? I know both are good.
Synthetic grease high speed grease. I just had to go buy another tractor to maintain. )</font>
There has been a lot of discussion on both of the above. Either oil would be an improvement...based on some comments in TBN and also in google groups I'm leaning toward Amsoil. As for grease, I have 2 grease guns...1 has regular synthetic grease and the other is a synthetic high speed...the high speed is for bearings only(mower deck, etc).
   / New PT-180 owner
Sounds like good advice. I'm sure Mobil 1 is excellent oil. After doing some reading myself, I think I am also going with Amsoil.
The less wear and the cooler it runs the longer it will last. I wonder if there are any Amsoil dealers on the PT forum. Would rather give them the commission.
   / New PT-180 owner #48
Barry:
Check the Oil-Fuel & Lubricants Forum. I think there are more than one Amsoil rep on the Board. You can sign up with the one closest, but Amsoil deals directly after you sign up.
I got in contact with Dave Spaay through TBN. He helped sign me with Amsoil as a commercial customer, with significant discounts.
Dave Spaay -- Certified AMSOIL Dealer/Account Direct http://www.UltimateOilTechnology.com
email: ultimateoil@comcast.net
630-267-9163
   / New PT-180 owner
Thanks Charlie,
Will do....... /forums/images/graemlins/ooo.gif
   / New PT-180 owner #50
Barry,
If you are considering the Amsoil hydraulic oil {HERE} you should keep in mind that it is currently designated as a multi-viscosity 5W30 weight oil. Formerly, it was designated as straight SAE 30/ISO 46 oil. ISO 46 is roughly a 20W oil, not 30, and maybe that's why Amsoil changed their lower viscosity limit and re-named the oil 5W30, eliminating the ISO designation altogether. Bottom line, Amsoil hydraulic oil is 5W30 oil.
IMO, in the southeast, it just doesn't get cold enough to warrant such a thin oil in the hydraulics. Remember that PT recommends 15W40 motor oil for the hydraulics. Many folks on the forum have reported better performance under stress, e.g., hill climbing, etc. when using even a higher viscosity motor oil in the hydraulic system, such as 15/50 or 20/50. A 15 weight oil should pose no problems with cold weather starts here, and the 40-50 weight upper spec will give you hydraulics the oomph under heat/stress that folks have reported here.
If you are considering a true hydraulic oil (as opposed to motor oils used in a hydraulic application) for your system, the 15/40 would roughly correspond roughly to an ISO viscosity number of 60-100 {HERE} . Amsoil does make a synthetic anti-wear hydraulic oil with an ISO viscosity of 68 {HERE}.
2018 Deere 323E (A53317)
2018 Deere 323E...
40ft 2-Door Shipping Container (A55851)
40ft 2-Door...
UNUSED FUTURE D3T 32" EXCAVATOR HYD TILT BUCKET (A57193)
UNUSED FUTURE D3T...
6ft S/A Trailer (A55853)
6ft S/A Trailer...
UNUSED RAYTREE RMSG29-29" HYD STUMP GRINDER (A57193)
UNUSED RAYTREE...
2 Cubic Yard Dumpster (A55851)
2 Cubic Yard...
