New problem on G6200
   / New problem on G6200 #1
wwr1964
Columbia Tennessee
Kubota G6200
Updating my progress on getting my late fathers G6200 back in service.
I now have the tractor running. I took off the mower deck and replaced the belt and freed up the belt tensioner. After reinstalling the mower deck I took it out to see if it was cutting even. The tractor now will not run while the mower is engaged. It takes it a second or two then starts to die until I disengage the mower?
Air still in the fuel lines? This only happens if the mower is engaged otherwise it will pull fine if I just ride it around the yard.
Any help is appreciated.
   / New problem on G6200 #2
Operator presence switch at the seat?
I think it activates when the PTO is engaged, which may explain why engaging the PTO kills the engine.
Well its not the seat switch. It will run for about a minute with the mower on the just starts to die.
I am completely clueless as what else it could be. Head gasket leak?
   / New problem on G6200 #4
With the PTO released (and engine OFF) do the blades spin fairly easily?
Wondering if it's a seized bearing in the deck or PTO driveline ...
Do you get a lot of smoke when engaging the PTO - either engine lugging smoke or belt slipping smoke?
Landoll Hauloll (A53472)
Landoll Hauloll...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A52377)
2019 Generac...
1261 (A50490)
1261 (A50490)
2013 ISUZU NPR STAKE BODY TRUCK (A52577)
2013 ISUZU NPR...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
