New problem on G6200
   / New problem on G6200 #1
wwr1964
Columbia Tennessee
Kubota G6200
Updating my progress on getting my late fathers G6200 back in service.
I now have the tractor running. I took off the mower deck and replaced the belt and freed up the belt tensioner. After reinstalling the mower deck I took it out to see if it was cutting even. The tractor now will not run while the mower is engaged. It takes it a second or two then starts to die until I disengage the mower?
Air still in the fuel lines? This only happens if the mower is engaged otherwise it will pull fine if I just ride it around the yard.
Any help is appreciated.
   / New problem on G6200 #2
Operator presence switch at the seat?
I think it activates when the PTO is engaged, which may explain why engaging the PTO kills the engine.
Well its not the seat switch. It will run for about a minute with the mower on the just starts to die.
I am completely clueless as what else it could be. Head gasket leak?
   / New problem on G6200 #4
With the PTO released (and engine OFF) do the blades spin fairly easily?
Wondering if it's a seized bearing in the deck or PTO driveline ...
Do you get a lot of smoke when engaging the PTO - either engine lugging smoke or belt slipping smoke?
CATERPILLAR 305E2CR EXCAVATOR (A51242)
CATERPILLAR...
2023 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2023 Ford F-150...
2019 CATERPILLAR 930M WHEEL LOADER (A51242)
2019 CATERPILLAR...
2025 LandHonor ABC-13-125A Hydraulic 42in Articulating Brush Cutter Skid Steer Attachment (A49462)
2025 LandHonor...
1998 VOLVO A40 OFFROAD DUMP TRUCK (A51242)
1998 VOLVO A40...
(INOP) CASE IH MAGNUM 180 TRACTOR (A50459)
(INOP) CASE IH...
