New Plow for FEL of B3300 or L2800 or similar
   / New Plow for FEL of B3300 or L2800 or similar #1
roaf3x
Bronze Member
Hello all.
I am shopping for a new tractor. Part of the decision is to give up the subframe plow with hydraulic angle and go to a FEL setup (Curtis) with a WR long remote.
Does anybody have experience with this setup? I am hard pressed to change if it isnot better.
thoughts?
RD
   / New Plow for FEL of B3300 or L2800 or similar #2
I have not used the Curtis brand, but I had two tractors set up this way to plow with.
I did not care for them because the added length gave the plow too much leverage to move the tractor from side to side when the plow was angled and I was pushing a heavy load. My tractors were in the 30HP range, so it might be OK with a heavier rig.
As you can see from my avatar I now have the plow hooked directly to the tractor. I find this setup to work much better for my use.
   / New Plow for FEL of B3300 or L2800 or similar #3
I had an L3130 with the sub-frame set-up,ok but limited lift was a problem and loss of FEL.Easier on the tractor for sure.I traded tractors moved up to a L4240 HSTC(6500lbs),built a Fel mounted Curtis plow set-up.I really like this set-up,can change to the bucket in minutes(with QA),can pile snow 9ft.high if needed.
The plow is definately further out front,may affect a lighter tractor more.
I run a rear blade also for snow removeal.
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
Unused Delta Crash...
Set of Ag R4 Wheels and Tires (A51039)
Set of Ag R4...
71062 (A49346)
71062 (A49346)
2014 PETERSON 4700B HORIZONTAL GRINDER (A51242)
2014 PETERSON...
2012 Mclaughlin V500LEHD Vac Trailer (A49461)
2012 Mclaughlin...
