New owner!
/ New owner! #21
Used mine this morning to pull my neighbors Dodge Ram up a snow packed hill. Slapped it in 4wd, low and 2600 RPM. Could barely tell I was pulling anything.
/ New owner!
When the motor starts to pull down more than you want, slowly lift on the hydrostat pedal until its back in the rpm range you want, think of it as shifting down in your car, takes a little bit to get used to.
Of course use the correct range for the job your doing.
It looks like they did a nice job installing your 3rd function valve.
And welded the ends of your cutting edge.
Did they say what year your tractor was manufactured?
Mine has a flat floor, I don't know when they changed to that.
It appears to be a 2013 manufacture...
/ New owner!
Nice rig!:thumbsup: I'd get some covers for the third function QDs on the FEL so no dirt/water gets in and contaminates you hydraulic fluid.
High is hardly ever used on these tractors, except for road travel.Medium is most often chosen 'gear'. Somewhere around 1800- 2200 RPMs for most work/travel, depending on load. Did you get your rear tires loaded for ballast? If not, definitely suggest doing so. Get a short section/ loop of hydraulic hose with QDs to connect your detented pair of rear remotes when nothing is attached so as to not deadhead the hydro pump, which will kill it if the lever is accidentally bumped into the A or B position with nothing attached.
Enjoy it- it gets faster after some use too....
Yep, was already thinking about QD covers, and the hose loop is an excellent idea, thanks! Tires are loaded with "blue stuff", whatever that is...
/ New owner!
Great advice folks, learning the HST is gonna be fun...
/ New owner! #25
Geeze CM, I use High all the time. I have one(only one) and part of that only one pasture that is nice and flat an level. With my Drum hay cutter I could cut hay at about 11mph.....talk about fun!
We have lot's of hill here, so when going back down, always in 4WD@ 2200 rpm(to keep from over rev-ing), yep High Gear all the way.
/ New owner! #26
OK, OK, you guys down in the flatlands have BUMPS that wouldn't qualify as a hill up north. That's why the term is country BUMPkins, right?!:shocked::laughing:
So you may use high whenever you want and not bog down:cool:
/ New owner! #27
I thought mine was 2013 also but no hump in the floor.
Do you have the "tier 4" engine?
/ New owner! #28
Ho ho ho....no not here....flat land is at a premium in our county:
The 100ac farm is outlined in red, 20ac bottom land pasture, the rest is a wee bit steep and the house is in the mddle of it all. But your right, I don't get to use High as much as I would like....mostly Med range though.
/ New owner! #29
Wow M7, that is some hilly property you got there! :eek: You probably need chains in the winter. :laughing:
/ New owner! #30
Nice area. Seems from the pics on photobucket you get some serious flooding when the crick rises, eh? What year was that?
/ New owner! #31
Smurfs?!
/ New owner! #33
Works for me.:laughing:
/ New owner! #34
We get floods every winter...it SOP here....last winter was 8 or 9 floods....with a couple of those moderate. As you can see from the topo, all rainfall/snowmelt goes to the creek bottom. The last "100 year" flood was in 93, before that I think 77 and before that the late 50's....I think the locals are confused as to what constitutes 100 years:laughing:
Sorry for the side track/////.......Charlie Mike
/ New owner!
image.jpgimage.jpg, couldnt attach photos in pm, not sure why, but someone asked for pics of where the 3rd function ties in, believe you have to pull the seat to see that, these were the best i could get with the ipad.
/ New owner!
Probably the worst pics ever! Sorry...
/ New owner! #37
Congrats on your new tractor. I got mine a few months ago and just hit 49 hours. The thing is a monster and always impresses me.
/ New owner! #38
Happy to finally make my first post, brand new DK45 HST, 3rd function (for the soon to be bought grapple), loaded R4s, Cutting edge on the FEL. Thanks Twin State Tractor!View attachment 349083View attachment 349084
Have had mine just a year now, std trans though. Fantastic machine! 500+ hrs, no problems worthy of mention. Sips fuel. Seems to pull its load through any mud hole and up any hill (given a little common sense) Could use a bit more power for pulling up hills, but this just means gear down and be more patient, it will get there before long.
/ New owner! #39
Congrats on the New Beast
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
2015 Nissan Frontier Ext. Cab Pickup Truck (A64556)
2015 Nissan...
2009 Infiniti FX35 AWD SUV (A64557)
2009 Infiniti FX35...
2008 JOHN DEERE 544J SUPER TRACTION WHEEL LOADER (A65053)
2008 JOHN DEERE...
2008 Toyota Camry Sedan (A61574)
2008 Toyota Camry...
Shell Gas Pumps Yard Art (A64557)
Shell Gas Pumps...
