NEW OWNER - Pics, and a few Q's
   / NEW OWNER - Pics, and a few Q's #11
The clamp on forks do work but from what others have mentioned, you probably couldn't use them to the full capacity of you fel lift without putting a little twist to your bucket cutting edge. If you were just needeing them for lighter stuff, then they do save money.
Dingo Man said:
Congrats on the new tractor. I did't realize there were any driveways 1000' long in Detriot:p Some articles I have read about the city it sounds like they are converting alot of the abandonded lots back to farm land. Maybe you can hire out yourself and your new toy:thumbsup:
LOL, well I work in the city, but commute from about 35 miles north of it; you couldn't pay me enough to live there.
Thanks for the input on the clamp on forks... I'd be using them to haul trees/logs, so maybe they wouldn't be the best idea. I don't know how to weld yet, but I'm planning to learn soon; the forks can be one of my first projects :tu:
   / NEW OWNER - Pics, and a few Q's #13
don't worry about the box blade !
I have a 72' inches Walco .... and have no problems pulling , you'll have to pull in low gear .
Anyhow , even with a 48 inches , you'd have to pull in low gear :)
I have done lots , and lots of grading with mine 500 hours + , without problems
That little tractor is a monster !
Well that's good to know!
Another question: can I add a larger bucket, or are we stuck with what came on the tractor.
And, I'll apologize in advance for any dumb newb questions; this is my first tractor and I'm still learning!
   / NEW OWNER - Pics, and a few Q's #15
Congrats! with a thousand pound lift I am not sure you could benefit from a larger bucket, but yes you can have any bucket fitted to your FEL with a little bit of welding. The brackets just have to be the same to fit the loader.
As for forks, I don't care for the clamp-on's. Next time you are in the city, see if you can find a place that sells forklifts. Stop by and ask how much they would want for a used pair of forks(osha makes them scrap them when they get too thin). I got a couple of sets for free that way, but I did flip the guy enough for a few good lunches. It looks like between you and your neighbor there has to be a welder. Weld a 2x2 angle iron across the top of the bucket. Then weld a couple of bracket on the back of the forks so you can "hook them" on the angle iron. This is where a toothbar is nice, the lower part of the fork can fit between the teeth so they can't move. While your at it weld a couple of chain hooks up there on the angle iron...they come in handy. Then go 'a forkin' ;)
   / NEW OWNER - Pics, and a few Q's #16
oupsssss sorry I mentioned 72 inches. box blade .......... it is actually a 60 inches !!!!
Sorry about that ! :confused2:
   / NEW OWNER - Pics, and a few Q's #17
Congrats on your new rig, I have almost the same setup only I have a 60"" box blade on mine (1200') driveway, I have had mine for around a year now. I absolutely love it, if I had it to do over again I wouldn't change a thing.You will wonder how you ever lived without it.............Craig
   / NEW OWNER - Pics, and a few Q's #18
Congratulations on your new tractor. I have an 03 CK 20 gear and it is a little brute. I would leave the factory bucket on it for a while if I were you and get used to it while you are getting used to your tractor. I know if I fill my bucket full of Florida dirt (sand) and travel with it, it is a pretty good load even with my 60" 450lb box blade on the back.
Just be careful with the wide box blade as ballast. If you are using the bucket in a pen or another tight place as you get close to the edge with your bucket your box blade will hit. Trust me I know this to be true :laughing:
   / NEW OWNER - Pics, and a few Q's #19
Great little tractor. However, that price sounds too low? It is a hydro? What was price before tax?
Thanks for the input fellas. I'm going to look into a tooth-bar soon. So far I'm lovin' this little tractor. Used it a bunch today to help cut-down and push down trees (in the direction I wanted them to fall) and help with the cleanup. Also used it do dig about 5 buckets worth of field-stone out of my ground. Pretty sweet little surprise; every time I dug deeper to loosen up a stone, I uncovered more!
Current promotion is a free loader (with cash, or your own private financing). Otherwise, you can do 0% financing from Kioti, but you pay for the loader.
Price: $13,900 minus $2137 (loader cost) = $11,763. Total with 6% Mich tax came to $12,648. The dealer's profit-margin was $1000 over cost, plus a $200 setup fee. So, basically the dealer bought the tractor from Kioti for $10,563... plus the loader, which was a dealer rebate for $2137.
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58216)
30 INCH TOOTHLESS...
UNUSED JCT 72" HYD BRUSH CUTTER (A58376)
UNUSED JCT 72" HYD...
Club Car Electric Golf Cart (A57149)
Club Car Electric...
