new owner of a kioti
   / new owner of a kioti #11
Welcome Tim, the shifting problem is just the nature of the beast I too have the lb1914, love it. Just try to slow down and double clutch, when I get in a hurry is when I start to grind the gears. I Bought used with 84hrs and not a clue on what I was doing. TBN has been helpful, theres not a hole lot of info on these compact tractors, that I can find. As for the year there is a thread for it, try to goggle it that usually will bring it up. There is also a frame color change blue was for upper 90s then went to grey frame for the newer models, along with two different engines. I hope this was helpful, glad to see another 1914 on here. :cool:
thanks for the info casey. yeah, i've learned to slow down too. i'm getting used to the shuttle shift, but it still pops out of 2 hi on occassion. also have to get used to the throttle direction (opposite of my fords). i didn't have any luck on the year search, will keep trying. do you have a loader or back hoe on yours? if so what model? thanks again.
   / new owner of a kioti #13
Hi TimPa,
Going by the serial# you gave it apears to be a 1994 year of manufacture.
The owners manual is out of production for that year, but the newer LB1914 owners manual part# 02883-20502
I tried to look up the in-service date, but it was way before we had warranty online services.
There are not too many companies that copy Kioti filters yet. You might find that WIX makes a fuel filter. The filters are reasonable from a Kioti Dealer and most will ship them to you if you don't have a local dealer.
The hour meter sounds like an internal problem in the meter itself. If the tach is working then the cable is OK(cable driven)
The shifting is most likely a wear problem and may have to be adjusted or re-shimmed.
Try not to lose patience with these guys they will be a big help to you more often then not. Occasionally we get side tracked but we can usually get your questions answered for you.
Good Luck and happy tractoring.
Welcome to the Kioti Forum
KiotiDave
   / new owner of a kioti #14
this is my first post here, i am sooooo glad to have found a kioti dedicated site. thank you for having me.
i just purchased a lb1914 sn 404000236 with a KL102 loader, and am looking for information i can not find in the owner/operator manual. i've read every post on the LB1914, and am happy to see there are few maintenance related posts. it tellls me the kioti is a good machine.
- 1* can anyone tell me the year it was made?
- 2* does anyone have a cross-reference list for filters (air, hydraulic, oil, fuel)?
- 3* it presently has 2 major problems
*3.1. the shifting isn't consistent, it occassionally pops out of 6th gear (at the gear shift) not when driving, but when shifting it there then trying to start off, and the shuttle shift is difficult to place in forward position sometimes, i may have to double clutch it.
3.2*. the hour meter doesn't work, tach does.
thanks in advance, i really appreciate your help and respect the knowledge on this board. sorry for the long post.
OK here goes:
1* - Contact a dealer with your serial number
2* - No. I recommend you purchase your filters from a dealer, at least one I know of offers free shipping on filter kits, that's what I've done two years running.
3.1* - Bring it to a dealer have it repaired. Or, as mentioned in other posts (hi-jacked), purchase the shop manual, another step I've taken which has been very useful.
3.2* - Purchase a new hour meter and install it, that's what I did when my brake light sending unit broke.
FYI,
Your response to initial posters does nothing to encourage others to respond after all this is a voluntary forum, right? What I mean to say is, we all take valuable time out of our days trying to help eachother.
Joel
thanks for the info, kiotidave. are you saying the tach cable is also the drive for the hour meter? i suspected it to be electrically driven.
i apologize if i ruffled feathers on my disappointment comment. i own several older tractors: 1949 ford 8n; 1979 ford 3600 w/fel, and the forums i regularly participate in are much more maintenance oriented, likely becaue the tractors age have allowed users to build a knowledge base. we go to dealers at last resort, not that they aren't good, but we like to work on the tractors ourselves. the forums are the best tool in the toolbox.
   / new owner of a kioti #17
Welcome TimPa and Pinkittens. I will second what a lot of folks have said about Rick Wallace and other dealers on this site, most will bend over backward to give you a helping hand.
I just had a problem with a leaking oil drain plug on my Kioti 45, with help from members on this site and a call from Rick to Kioti the fix has been made. Now I don't have to hop off the tractor every five minutes to make sure the plug is still in place.:)
   / new owner of a kioti #18
Hi TimPa,
The cable drives the tach and the tach internally drives the hour meter. If the tach is working correctly, then the problem is inside the meter head. At least this is how the more recent models are. I have not worked on a mid nineties LB1914.
You may want to get a 12 volt hour meter and tie it in somehow with the alternator output so it only regiters when the engine is running. I think that is what Joel had mentioned in an earlier post.
Hope this helps.
2014 AMERITRAIL TUGGER TRAILER (A58214)
2014 AMERITRAIL...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
Generator (A56857)
Generator (A56857)
2013 PRIME TIME RV LACROSSE (A58214)
2013 PRIME TIME RV...
