New Owner of a 1997 HDS 3185 Cub
   / New Owner of a 1997 HDS 3185 Cub #21
Good point. But that pulley seems fine. The bar supporting the mower deck had worn to the extent that it was actually scraping the pulley, so I double-checked it anyway. I replaced that part and all is fine now.
From talking to a few old Cub Cadet mechanics, I think its the driveshaft adapter at the point where it connects to the engine. The adapter apparently used a strange configuration and multiple small spacers that somehow cause it to all fit together. I'm told that the spacers can get loose and make a lot of noise. But the only damage is to the adapter, etc, which I'll have to remove and replace. But I'd have to remove and replace it to fix it now or later - so I'm leaning toward just letting it be for a few months and using it until I get time to fix it. If it breaks, I'm no worse off either way I don't thionk.
Bad decision. Shaft parted as I thought likely. But, in doing so, it bent and damaged the flywheel fan/screen. And those parts are all not only expensive, but show as not available on parts stores. I'm still checking. It'll cost me $300 in parts at least. I should have fixed it up front... Particularly now that I know how easy the engine comes out so you can get to the drive shaft. I guess I chalk it up to experience - a good lesson.
   / New Owner of a 1997 HDS 3185 Cub #22
Just a report to note that I found all parts for the 3185 - some used - and put it all back together. The machine now runs fine. All parts work - and it ultimately cost me about $245. I'll have some other minor work to do on leveling the deck and such, but am pleased to have a strong tractor for cutting beside my driveway and other non-lawn areas. I plan to replace some gaskets this winter to stop a bit of an oil seepage, but all else looks good.
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
New Holland 57 Rake (A53316)
New Holland 57...
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A55851)
2025 84in Dual...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56129)
2017 FREIGHTLINER...
2018 MITSUBISHI OUTLANDER SPORT (A55745)
2018 MITSUBISHI...
2016 Ford E-450 Passenger Bus (A55788)
2016 Ford E-450...
