New Owner of 3510
   / New Owner of 3510 #1
ClearRock
Hello, I'm a new member here, but I've been reading for a little while. I bought a used 2004 Branson 3510 with 232 hours after reading about the good reviews here. It will be delivered tomorrow. It looks small. I was wondering if it would be powerful enough to run a square baler? My father run this baler with a old Farmall 350 Diesel. It is a heavier Tractor, but the HP is about the same.
The Branson PTO has two speeds. What is run on the high speed PTO?
I am sure I will have many more questions as I get use to the Branson.
Thanks in Advance.
   / New Owner of 3510 #2
Good luck with your new toy, then again Branson's dont require much luck ;)
Dont have a clue about the baler but I have been known to run my
4720 in the 1000rpm range at about 1/2 throttle while doing lite bush hogging and
or cutting grass.
I have a 5ft bush hog and a 6 ft finish mower, my 4720 has plenty of
power to run these at about 1500rpm's which is close to the 540 range.
Gene
   / New Owner of 3510 #3
Congratulations on the new (to you) tractor. I also cannot tell you whether or not you can run a square baler, but I imagine that horsepower is horsepower. If the horsepower at the PTO of the Branson is comparable to the Farmall, then I would say you have a good chance of being able to run it. I was told by my dealer that there were not many implements that would be run at the 1000 RPM PTO speed. I've never had mine out of 540, but all I run with it is my rotary cutter.
I hope you enjoy your tractor, they are built pretty tough.
Mark
   / New Owner of 3510 #4
Thanks in Advance.
Congrats on the purchase!
On my 3510i the "1000 RPM" setting is referred to as the 540E (for economy) setting. I've used it for light brush-hogging, as the 540 PTO speed is met at only 1700 RPMs vs. 2500-2600 on the "normal setting."
Saves fuel if you don't need the engine muscle...
As for the baler - I Couldn't tell you...
Good Luck!
Lunk
   / New Owner of 3510
Thanks for clearing up the PTO speeds. Makes sense.
What about a Roll Bale Spear to fit the FEL. Seams I read here that if it has the Branson hookup it will require the Branson Spear. Is that correct?
   / New Owner of 3510 #6
i've square bayled a lot of hay with a ford 3000 and i own a 3510i now. i think the branson would do alright on flat fields , but it would worry me on hill-sides. i had the back wheels spred out on my ford that made it alot more stable. a square bayler can shake you up quite a bit. most of the fields i mowed and bayled are quite steep. i'm in central kentucky. how hilly is it where you are?
   / New Owner of 3510
Robbianderson,
Flat to rolling in Southern middle TN.
Thanks
   / New Owner of 3510 #8
Branson has their own hookup or you can order the Branson FEL with skid steer. I have the Branson BL10A loader and a dealer quoted me a bit over 500.00 for the Branson spear. I had a welder that makes bale spears make a couple of brackets that fit the Branson hookup and weld those to his bale spear frame and PRESTO--works perfectly for about 175.00 less. :)
   / New Owner of 3510
Ace,
Yeah, $500 sounds pricey for the spear. I know a good welder so I may have to try that route. I have a Branson FEL, so it probably requires their spear.
   / New Owner of 3510 #10
Ace,
If you have the BL10S loader it will accept the same attachments as a skid steer, BL10A loaders are the ones that take Branson implements.
Mark
(4) 64" X 40" ALUMINUM POP-UP SIDE WINDOWS (A51248)
(4) 64" X 40"...
2019 TAKEUCHI TL12V2 SKID STEER (A51246)
2019 TAKEUCHI...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
AGT HPW3000-1 (A50123)
2015 Linde H35D 4,350lbs. Diesel Forklift (A51691)
2015 Linde H35D...
Bush Hog R0-720 Roll Over Box Blade (A51691)
Bush Hog R0-720...
