New Owner Here - Question About Slopes
   / New Owner Here - Question About Slopes #1
Zippo1
Near Bellingham, Wa
New Holland TC40A
I'm new to tractors and have recently acquired a new to me NH TC40A. I've been trying to read and learn all that I can and thank you folks here very much for all the info you present. One question I have but have not been able to find an answer to concerns "slopes". I understand the need to run up and down a slope but am not sure at what point a slope changes from a, "side to side" operation is not a problem to OMG! Suggestions and guidance would be appreciated.
   / New Owner Here - Question About Slopes #2
It goes to OMG when the pucker factor on your seat reaches maximum.
Early on w/ my B7610 I had a full bucket of sand carrying it about a foot off the ground. Right front tire dropped in a hole.
I had to hike my body out and drop the bucket. Pucker factor was high.
Just take it gradual.
Thanks, newbury. I'm so new I found myself jumping a little as it just bounced from side to side going through the field. :)
   / New Owner Here - Question About Slopes #4
If using a lot on slopes;have your rear tires loaded and the rear wheels widened as much as possible.
   / New Owner Here - Question About Slopes #5
Go SLOW. A lot of folks don't have a built in pucker factor and have to "learn" by careful experience. As NYBIRDMAN said - load and widen the rear tires. This will allow operations on steeper slopes - but be aware, you can still roll.
There are those incline meters that can be installed - but one big drawback - if a tire drops in an unseen hole - the meter isn't going to keep you from rolling.
When operating horizontally on slopes - keep the bucket LOW and any load LIGHT. If you are lucky - the first indication is the up-slope rear tire will start to lift, maybe even spin a little because its loosing traction.
Another suggestion - if it doesn't look good, don't go there or do it. Wait until you have more seat time.
And BTW - Welcome to TBN and the forum.
   / New Owner Here - Question About Slopes #6
Thank you.
(APPROX. 640BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 640BF)...
30ft Highway Trailer Co. Lowboy (A55315)
30ft Highway...
Kivel Quick Attach Forks (A56469)
Kivel Quick Attach...
Brazen Cattle Shute (A56469)
Brazen Cattle...
2013 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2013 Freightliner...
2014 Ford Taurus Sedan (A55853)
2014 Ford Taurus...
