New or Re-built Alternator?
/ New or Re-built Alternator? #1
Travis_R
Livingston Parish, LA
Yanmar YM2500
97' Mahindra 485 DI
Don't know the price on getting mine re-built, but the new one is $125.00 plus tax and shipping from my Mahindra dealer. He said that he has it in stock.
Should I go new, or get the old one re-built??? How long should I expect the the rebuilt one to last??? Should my choice be made on the price difference between the two??
Thanks,
Travis
/ New or Re-built Alternator? #2
Call a couple of auto-electric shops in your area. Should be able to rebuild for about $60 or so. BobG in VA
/ New or Re-built Alternator? #3
<font color="blue"> How long should I expect the the rebuilt one to last? </font>
That really can't be answered. The reason is because it all depends on how the shop rebuilt the unit. Some just replace the defective part and others completely go through everything.
/ New or Re-built Alternator? #4
I've had as good luck with local shop rebuilts for starters, alternators, etc. as with the new stuff at the parts house. Ask around, most folks with bad experiences want to give the seller his money's worth of advertising.
/ New or Re-built Alternator? #5
Usually its just the internal voltage regulator module that goes bad.
The windings only go bad if there is some sort of a short, which rarely happens.
/ New or Re-built Alternator? #6
Travis -
As Jerry said, how long the rebuilt lasts depends on the rebuilder. If it's done right, a rebuilt should last just as long as a new one. A good rebuild would include new brushes, bearings, diodes and probably the internal regulator. I'd just go with whatever is cheaper, and I have a feeling you can do better than $125 having yours rebuilt at an auto electric shop.
John
/ New or Re-built Alternator? #7
Way back when my Dad owned an auto parts store, the rebuilt ones we sold had the same guarantee as new ones, and were ever bit as good as the new ones.
/ New or Re-built Alternator? #8
There are two parts houses in the small town that I live close to. If you buy rebuilts at one, they will last as good as new. If you buy at the other place, you will be buying again in a year or less.
PROBLEM FIXED!!!!
Well, the answer to my question is NO the alternator was not charging. Why??????? BECAUSE OF A SIMPLE BLOWN BULB!! The charge light indicatior bulb was blown. Of course I didn't know it at the time.
My dealer Mike (Singleton Sales & Service in Franklinton, LA) told me to check the bulb. If its blown, for some reason the charging system won't work.
He was right.....Went to Autozone and bought a pack of 2 for $8.00 and now my charging problem is over.
THANKS TO MIKE AND EVERYONE ON TRACTOR BY NET.
If I did have to choose between a new or re-built alternator, I would have had mine re-built- just from reading the posts on this thread.
THANKS AGAIN,
Travis
/ New or Re-built Alternator? #10
Mike from Singleton Sales - I have to reiterate Travis's thank-you for the advice. The dealers that respond in this forum are not only out there for the sales but they really want to help out if they can. I never had this problem but I have the info safely stored away just in case it happens to me. $8 bucks is a whole lot cheaper than a new alternator for $125 and even then it would not have fixed the problem. Thanks - Clyde
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63688)
2012 MACK Tender...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61572)
Pallet of...
2011 Isuzu NRR Dovetail 22ft. Flatbed Truck (A61573)
2011 Isuzu NRR...
ATS Mini Excavator (A66285)
ATS Mini Excavator...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
UNUSED WOLVERINE HYD AUGER ADB-13-1218R (A64281)
UNUSED WOLVERINE...
