Loader New Options for Mahindra 26XL not seen before ie...quick attach and cab??
   / New Options for Mahindra 26XL not seen before ie...quick attach and cab?? #1
bigredcustoms
In the Trees, Pineyland
Mahindra MAX 28XL
I guess 2015 Mahindra Max's are seeing some new options. Namely a cab with heat, and curved boom loader with quick attach. I 've already seen a member on here with a new 26Xl TLB, and his loader is clearly different. Nothing in mahindra parts yet to get part numbers assuming the pins are spaced the same. Any info from the dealers on the forum? A tractor house listing to check out the pics since I don't want to copy their images. http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=9150759
   / New Options for Mahindra 26XL not seen before ie...quick attach and cab?? #2
My new 26xl has the quick attach skid steer bucket. It also only has the one center support for when you disconnect the complete loader. All other info and pics I saw on the 26xl showed the loader with two supports and no SSQA.
I'll have to wait to call the dealer. The idea of having a factory SSQA on is nice. Hoping they hadn't changed the pin spacing or width too much. Good to know thanks and enjoy your machine. I've added a few things to mine, and it's by far the most used machine in the inventory;)
   / New Options for Mahindra 26XL not seen before ie...quick attach and cab?? #4
Usually when cab models are made things have to be routed differently so I doubt youll see a part number for the hardcab but there is a soft cab available.
   / New Options for Mahindra 26XL not seen before ie...quick attach and cab?? #5
I actual drove the Max26XL Hydro CAB QA Loader at www.knoxland.com/ In Warner NH a little while back this winter. Curved beam loader with QA is a step in right direction. I wonder if it is a SSQA?
I was very impressed how nice the cab was.
   / New Options for Mahindra 26XL not seen before ie...quick attach and cab?? #6
I actual drove the Max26XL Hydro CAB QA Loader at Knoxland Equipment In Warner NH a little while back this winter. Curved beam loader with QA is a step in right direction. I wonder if it is a SSQA?
My 26xl HST has a SSQA bucket. Think it may be standard on the 2015. I didn't pay extra for the option anyway.
KOMATSU D51PXI-24 CRAWLER DOZER (A52707)
KOMATSU D51PXI-24...
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
2012 Case IH 1250 24-Row Early Riser Planter (A53485)
2012 Case IH 1250...
2017 Autocar Xpeditor T/A New Way 31Yd Side Loader Garbage Truck (A55852)
2017 Autocar...
Willmar 4500 Wrangler Articulating Loader (A55314)
Willmar 4500...
TORO TRX20 STAND ON TRENCHER (A52707)
TORO TRX20 STAND...
