New MX5100 delivered today
   / New MX5100 delivered today #1
juddspaintballs
Berkeley Springs, WV
Kubota MX5100 HST
This is my first tractor. Other than clearing the driveway, I don't know exactly what I'll be using it for yet, but I have plans. FEL's are very useful, I may get a snow blower, I definitely want some pallet forks for the FEL, I could use a post hole digger for putting up a few acres of fence, I might brush hog, and I'll probably get a grapple. I'm sure I'll find other uses for it, however.
My dad has a BX2330 that he's been abusing for 10 years, and after looking at Mahindra and New Holland tractors, I decided I wanted a Kubota. I started off liking the B series, not really knowing what I wanted or needed, just knowing that the BX was too small for my property. It didn't take long for me to jump up to liking the L3200 for the heavier frame. After thinking that I might need to brush hog some of this place, I moved up to liking the L3800 for PTO horsepower, and then very quickly the L4600 with the minimal price difference. After a bit more poking around, I found the MX4700/MX5100 to be very closely priced to the L4600 so moving up to an even larger tractor with bigger FEL capacity, heavier weight, etc. etc.
I finally settled on the MX5100 with FEL and W. R. Long third function valve. I had to have the SSQA on it and I got the grille guard and rear tires filled with Bio Ballast. $28,400 financed for everything delivered to my house 90 miles away from the dealer and they filled the fuel tank to the top for me too. The dealer even gave me a set of hoses for whatever front implement I get to hook up to the third function.
It was delivered with .4 hrs on the clock and now it has 1.6 hrs on it. I drove the girls up and down the driveway with it and lifted my MEP-003a generator out of the trailer it was in and put it in my shed. 1300 lbs of generator in the bucket (secured with straps and sticking out about 2' past the bucket) makes the rear end light. I really need to turn one of my barrels into ballast very soon. I pushed over a tiny tree and broke off a few low lying branches too. With the ROPS folded, I can back the tractor into my garage with about 2" of clearance for the garage door opening. The tractor will live in the garage until I build a run-in for it behind the garage.
Obligatory pictures:
20140327_160952.jpg 20140327_161003.jpg 20140327_161014.jpg 20140327_161032.jpg 20140327_161044.jpg 20140327_161053.jpg
   / New MX5100 delivered today #2
Very nice. Big for a first tractor. Be careful. Keep the kids away when you are working.
   / New MX5100 delivered today #3
Congrats, it will be a good one. The one I have at work has been tough. You are right it will get light on the back end pretty quick, ballast is essential for sure.
Yep, big for my first tractor purchase, but I'm not completely new to tractors. I've put many hours on my dad's BX and in college I worked for the Grounds department and they had a ~40 HP Deere with power shuttle that I often used. I pulled the batwing mowers a few times with the big Deere a few times too.
Our church is right by Tractor Supply. I have something to return there soon, so I'll buy what I need to make my 55 gallon drum into ballast and fill it up with concrete very soon. Any idea how many bags of 80# that I need to buy?
   / New MX5100 delivered today #5
Congratulations, on your new tractor, I would have had some rear remotes, but you can always do that later, hard to think of everything, I know I sure didn't.
Debated it right before I had it delivered and wound up liking the idea of not spending an additional $2400 for factory remotes right now. I'll probably build my own setup down the road for those.
   / New MX5100 delivered today #7
Nice ..
Sent from my iPhone 5 using TractorByNet
   / New MX5100 delivered today #8
Gosh that sounds high, I got three rear remotes with TnT cylinders and don't think I paid that much. I think you can get them much cheaper from FitRite, I bought my hydraulic toplink for the 8540 from him and it is as good as the OEM.
Trojan 8T-50 46in Hydraulic Thumb Excavator Attachment (A51691)
Trojan 8T-50 46in...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
2018 John Deere 8370R MFWD Tractor (A53342)
2018 John Deere...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
2003 Ford F-250 4x4 Pickup Truck, VIN # 1FTNW21P33EC85506 (A51573)
2003 Ford F-250...
