New MX4800 owner
   / New MX4800 owner #11
Good read & congrats on your MX! I've got an MX5800 that I just bought 2 months ago & love it. She's a beast for sure & have had it on some pretty steep sidehills at my mountain property. I'm running filled R4 rears set to the 2nd widest setting.
   / New MX4800 owner #12
Thumb thugs need to find another discussion forum website.
My apologies for my part in 'poking the bear.' Hopefully the OP comes back around. Slopes and tractors deserve attention.
   / New MX4800 owner #13
Rbtjr,
Agree w/ you in that my MX would appear unstable above the 15 degree slope you describe. The OP has not corrected the assertion that he mows on a 3/1 slope so it is unreasonable to make corrections or interpretations as to the intentions of his post.
My MX tires are not loaded as the extra weight during spring mowing is a detriment albeit it does have R-4 shoes. I also have an aftermarket cab weighing 900 lbs. and that alters slightly, the tractor center of gravity. My width is set to 74 inches, outside to outside.
A 3:1 slope is 71 degrees. It is a completely reasonable assumption by everyone on this forum but you that the OP does not mow a 71 degree slope. If he does, then you are correct and we all are wrong and you'll have our heartfelt apologies. Until that happens, I suggest you let it go. Thanks. :cool:
   / New MX4800 owner #14
Clarification: On our MX5800, the rear wheels spread as wide as possible measure a little over 78" outside to outside, and our R4 rear tires are loaded. We have an FEL which we leave on all the time but no cab or anything else that would substantially raise the center of gravity. Our MX is IMO as stable as our prior L3800 with R4 tires, loaded, on which we had installed 4" spacers on each rear wheel for added stability. So, all in all, I think that our MX is pretty stable. Still, I don't mow on steep slopes, but then again I don't have to because I can easily avoid doing so.
   / New MX4800 owner #15
Moss,
Attempted issue summation in post 4, Tractor Girl offered assistance in post 5.
Perhaps you would consider your 8 ft distance analogy as a "sticky" posted at top of general forum, owner operating, as clarification for members, Tractor Girl chart also helpful.
   / New MX4800 owner #16
Mx5800 here with R1s. What's the widest stance setting, outside to outside, in inches?
   / New MX4800 owner
Hi gents,
I'm not offended in any way. The documentation for this job contract states a slope of 3/1 which I assume to mean a drop of 1 foot for every three horizontal feet. Parts of it are very steep! I've had the tractor for a bit and have not changed anything yet - I've only mowed one 10 acre field with varying degrees of slope and graded a long driveway. The meter reads 16.8 hours. This particular job is coming up at the end of September. My plan is to ask the dealer to set the wheels out to their widest possible setting and try it like that. (I can't figure out a way to move the tires loaded with 513 lbs of Ballast Star around myself). My heavy 6-foot flail mower is offset to one side and sits very low...I think that helps a bit. So far, I like the ag tires...they seem to offer better grip in tall, moist grass without tearing anything up unduly.
The tractor is nice enough. It seems to have less power than I expected. The HST trans is very smooth, as is the engine. I added the Kubota deluxe fiberglass canopy. Hopefully that doesn't raise the center of gravity much.
I'd add rear wheel spacers if possible, but I don't see anyone who makes these for an MX.
   / New MX4800 owner #18
I’m waiting on delivery of a MX4800DT. It’s my first tractor and I’m also on a slope in the Sierra foothills. Was thinking to change the R4’s to R1’s. I read they have more traction. Wanted pulling and pushing traction for grading. But dealer said I would lose 8” in tread width and gain height. So staying with the R4’s. They will be loaded. Was thinking of wheel weights for the rear tires to lower the center of gravy. Manual says up to 310 lbs. per wheel. Also did not know you can widen the track on the MX. I knew about the larger tractors. Thanks for the info. Was also thinking of wheel spacers but concerned it would add more stress on the rear axle bearings.
   / New MX4800 owner #19
Hi gents,
Your MX has the same type wheels as my L4701. I’m aware some of the smaller L01’s have non-adjustable wheels but mine are like yours. I considered moving mine. Loaded, mine are a bit over 500lb so at least one appropriately sized tire handler is needed to do it safely. Depending on where they’re set now you may even have to take them both off simultaneously to swap them to keep the tread correctly oriented, which would require two tire handlers. Your plan to have the dealer take care of setting the width is definitely a wise move. Simple job if you have a smooth floor and a couple of tire handlers. Quite dangerous otherwise.
   / New MX4800 owner #20
Read on a Dealer site the MX with R4 tires loaded will add 400 lbs per tire. That was on Messicks. Also the MX can take up to 310 lbs per wheel with weights per the Manual.
2013 Heartland Elkridge 37UL 37ft. T/A 5th Wheel Travel Trailer (A55853)
2013 Heartland...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
2025 14ft. Bi-Parting Deer Motif Driveway Gate (A55853)
2025 14ft...
Push Mower (A55973)
Push Mower (A55973)
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2007 Kenworth T800 Tri Axle Day Cab Truck Tractor (A56858)
2007 Kenworth T800...
