Mowing new mower wheels
/ new mower wheels #11
<font color="red"> When you say Hard foam, is that like construction foam you spray around doors and windows? </font>
A local shop sent it to another. It is a system touted as particularly for tires. It seems really hard and heavy, so I doubt it's construction foam -- more like dense foam rubber.
/ new mower wheels #12
When I got mine filled I beleive pt sent them out. It is a hard rubber like they fill mine tires with. I did once try the construction spray in foam on a small cart that you pull behind the tractor. There is a story with that though, the cart wheels when I first got the cart keept going flat so I used a can of fix a flat in it and it worked fine for a while but I beleive it was the fixaflat that caused the rim to rust a big hole in it. When I needed to use the cart I noticed the flat and the hole in the rim and I needed to haul some stuff and at the time I couldn't find a replacement tireand rim so I got a peice of valley tin and put it inside the wheel over the hole in the rim took the valve stem core out and filled the tire with the spray in foam through the valve stem. When I saw how fast it swelled the tire out I thought I was going to have to duck for cover. The tire held up long enough for me to haul what I needed to haul and was still hard when the tires and rims that I ordered came in to replace it. I wished I had keept on using it to see how long it would have held up but too late now I threw it away. I wouldn't advise anyone to do that on a good rim but for that job it held up and keept my attention every load I hauled I'd look at it with amazement.
Echo SRM2620 Gas Trimmer (A60352)
Echo SRM2620 Gas...
2007 Ingersoll Rand G240 214kW 3-Phase Towable Diesel Generator (A59228)
2007 Ingersoll...
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
2011 ORTEQ TANK MANIFOLD (A60736)
2011 ORTEQ TANK...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
