New MF GC1705 on the way!
   / New MF GC1705 on the way! #1
Imold
Platinum Member
West Central Mn.
MF GC1705, Cub Cadet RZTL, Husqvarna Rider.
Well I went back and after a lot of talking I bought a GC1705 with FEL and 60 inch MMM and then I bought a 60inch back blade and a 48inch box blade, all said and done it was just under 16k for it all.
They had a 1715 on the lot but I decided the 22.5 hp would be fine and the salesman figured it would work ok for what I need it to do and with the difference I can afford the Bush Hog 48 tiller in a few weeks so I値l be all setup to work my property.
I値l post picks when I get the 1705 home, they need to fit the MMM on it and then I can pick it all up, probably later this week.
Jim.
   / New MF GC1705 on the way! #3
well that sounds like work to me but at least u have some help now doing it :) have fun and post pix!!!!
It will be interesting to see if I can disconnect the mid pto shaft, I had to lay on the ground just to see under the tractor because of my disability I can not just kneel down and look under the tractor like normal which is one of the reasons I was considering a 3 point finishing mower, would be much easier, just have to see how it goes with the MMM.
I’m going to pick up the Box blade and Back blade tomorrow and the tractor and mower by Friday hopefully.
   / New MF GC1705 on the way! #5
I just sold a 1705, good little tractor. I hope you aren't planning on taking the MMM on and off often, the driveshaft is a pain.. If you're place is wide open I would opt for the finish mower..
It’s all open and basically flat, I wanted to stay at 60 inches wide and will see how it goes the rest of this year and maybe next year I’ll invest in a used 60” finishing mower and see how it works with the 22.5hp motor/18.3 pto, seen them used for around 1k and if it doesn’t work selling it will not be a issue around here, most recommend at least a 25hp engine but I’ve seen a couple less expensive ones that say up to 40 hp and in the reviews I read a few reply’s were using 18 and 20 hp tractors with the 60” with no issues.
Right now I’m mowing with a Cub Cadet 54inch RZTL every Thursday except if it’s raining so this 60inch MMM should be a welcome treat plus the ride alone is going to be nice compared to the Cadet, the Cadet will still get used for my ditch sides.
   / New MF GC1705 on the way! #7
The 1705 has more PTO hp than most 25hp tractors. I ran a 60inch delmorino finish mower and it ran it fine..
I’ve done a bit more looking at the finishing mowers and I don’t know what I was thinking, got my wires crossed or something but the 1705 would handle most 60” finishing mowers out there, maybe I was thing of the brush hog used for heavy overgrown areas, that would be a 48” for the 1705. All a teaching moment for me.
Jim.
Here are two items I picked up today for the 1705.
   / New MF GC1705 on the way! #10
Jim.
Yes I ran a 4ft bush hog and in heavy grass a 5ft would have been to much.. My aunt just bought a kubota with a MMM, she is pretty tough but she has a hard time with the hook up so she is returning it for a 3pth finish mower..
2015 PETERBILT 567 TRI-AXLE (A52472)
2015 PETERBILT 567...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
Gravely Tractor (A50325)
Gravely Tractor...
2016 Kia Cadenza Sedan (A51694)
2016 Kia Cadenza...
2001 Volvo VNL Truck, VIN # 4V4N19JF51N250353 (A51572)
2001 Volvo VNL...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
