New Member
/ New Member #1
mnKirk
Minnesota
Branson 3520CX
Hi tractor enthusiasts, I'm Kirk from northern Minnesota. We live on 60 acres of pasture and woods, and use my little Cub to do just about everything. Kind of exploring what my tractor options are after owning the Cub for twenty years.
/ New Member #4
WELCOME!
How many engine hours have you put on the Cub Cadet during twenty years?
Cub Cadet 7260
1998 - 2003 7000 Series
Compact Utility tractor
Series next: Cub Cadet 7265
Manufacturer: Cub Cadet
Original price (USD)
$14,600 (2003 )
Variants:
7260: gear
7265: hydrostatic
Cub Cadet 7260 Engine:
Mitsubishi 1.3L 3-cyl diesel
Cub Cadet 7260 Power:
Engine (gross): 26 hp [19.4 kW]
PTO (claimed): 23 hp [17.2 kW]
Capacity:
Fuel: 7.9 gal [29.9 L]
Front axle: 4.2 qts [4.0 L]
3-Point Hitch:
Rear Type: 1
Control: position control with optional draft control
Rear lift (at 24"/610mm): 1,653 lbs [749 kg]
Power Take-off (PTO):
Rear PTO: live
Rear RPM: 540 (1.375)
Engine RPM: 540@2376
Mid PTO: live*
Mid RPM: 2000
Engine RPM: 2000@2632
Dimensions & Tires:
Wheelbase: 65 inches [165 cm]
Weight: 2,315 lbs [1050 kg]
Front tire: 7-14
Rear tire: 9.5-24
Cub Cadet 7260 attachments:
mowing deck
front-end loader
backhoe
Mechanical:
Chassis: 4x4 MFWD 4WD
Differential lock: mechanical
Steering: hydrostatc power
Brakes: mechanical wet disc
Cab: Two-post foldable ROPS.
Hydraulics:
Type: open center
Pressure: 2133 psi [147.1 bar]
Valves: 1 or 2
Pump flow: 7.8 gpm [29.5 lpm]
Electrical:
Ground: negative
Charging system: alternator
Charging amps: 50
Charging volts: 12
Battery:
Number: 1
Cold-cranking amps: 500
Volts: 12
Page information:
Last update: December 5, 2014
Copyright: Copyright 2016 TractorData LLC
Contact: Peter@TractorData.com
/ New Member #5
:welcome: to TBN...enjoy.
/ New Member #6
Hi Kirk. Welcome to the forum!
Hopefully, we can help with the decision process :)
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A62131)
UNUSED RAYTREE...
UNUSED RAYTREE RMSG29 - 29" HYD STUMP GRINDER (A62131)
UNUSED RAYTREE...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
UNUSED WOLVERINE SB78-78" ROCK BKT (A62131)
UNUSED WOLVERINE...
2025 GIDDY UP 7'X14' BLACKOUT XTREME CARGO TRAILER (A62130)
2025 GIDDY UP...
UNUSED ATS EPC40 ELEC.PLASMA CUTTER (A62131)
UNUSED ATS EPC40...
