/ New member #1
Schoony
Lumby British Columbia Canada
1942 McCormick W4
I am trying get my old 42 W4 to stop flooding. I have had the carb off so many times I think I should just use velcro. I have cleaned and checked every part in it but it floods so bad it is filling the crankcase with fuel. Any ideas at this point would be of great help.
I am 63 years old and this thing is driving me nuts. It defies all the laws of mechanics.
/ New member #2
Schoony, I can't help you with the carburetor, but welcome to TBN!
/ New member #3
G'day Mate and welcome t TBN from Downunder.
I'm sure that someone will be along to help you with your enquiry... Or Catherine will shift your thread to where help can be had.
Enjoy the site.
/ New member #4
:welcome: to TBN Schoony...enjoy.
/ New member #5
Welcome to THE tractor place. You mention you've had the carb off and checked all the parts - have you actually put in a new kit? Have you replaced the float? It could be time for a new carb too - like you and I, they simply wear out over time, seats begin to leak so no matter how new the needle valve is, it will not seal. Just some thoughts.
You should make a new thread on the general maintenance parts and repairs forum as well, maybe on the McCormick forum as well - someone(s) will certainly have some suggestions.
/ New member #6
:welcome: Welcome to the forum!
:tractor: I'm going to move this thread over to our McCormick section.
/ New member
I am new to all this forum stuff on the interweb so you might have to guide me in certain directions. I put the carb back on yesterday and it still floods but not as bad. I have a call in to a dealer to see if he can get me a kit. It still smokes like crazy and is blowing oil and raw gas out the exhaust. I checked the compression and it is at 80lbs across the board. I have a 1952 parts tractor so i am going to swap the head. I think I might have dropped a valve guide or something. Seems this is a two part problem. I will keep you posted as to my progress or lack thereof.
If you can't fix it with a hammer it must be electrical!
/ New member #8
Did you check to see if maybe the float has a pinhole in it, and has gas inside..?? If not that, if the little keeper spring, if it is still there where the pin that holds the float in place, can get in a position, when slipping the bowl back on, that will bind, and keep the float from completely rising. Just simply holding the float up, with fuel on, will let you know if the needle valve is completely shutting off the fuel flow. If holding the float up shuts the fuel off, then it's just a matter of adjustment, or, finding out what's binding the float, not letting it rise.
You can actually make a tool to "see" how much fuel is in the bowl, if you get it closer to the level it should be. The drain plug in the lower portion of the fuel bowl should be 1/8" npt. Go to a hardware and find a 1/8" npt barbed fitting, and screw in there. Also get about 12" to 18" of clear vinyl tubing. Slip it on the barbed end, and turn up, and tie off to something, to keep it upright. Turn on fuel, and the level of the fuel in the tubing, is the level in the carb. bowl. Of course, this won't help much, until you get the fuel flow stopped at a certain point. That's just for the final tweaking. Fuel level should be about 1/4" below the top of the fuel bowl.
/ New member #9
Similar to the previous comment.... Years ago, I forgot to run the carb dry before the winter on my 1953 JD 40. Apparently, there must have been some water in the carb and it froze during the winter. The float was made of metal and was crushed a little by the ice. That caused a crack to form between the two soldered halves of the float and the float filled with gas so it could not close because it no longer floated. I discovered this when I noticed I was using a lot of gas and then saw it running onto the ground. When tearing down the carb, I found the cracked float, drained and dried it out making sure there were no more fumes, and re-soldered it. It has been fine ever since.
/ New member
I made the tool as suggested and that was not the problem. Got a carb kit and installed it. I put it all together and ran the tractor. No fuel leaks but would not run without the choke on and lots of smoke and oil. I pulled the head yesterday and one of the valves on no 4 was shiny behind the spring so I think the guide is shot. I am going to pull the head of of the 52 and see if it is good enough to use. I will keep you updated. Any ideas?
/ New member #11
Just a couple of ideas. I rebuilt a '48 Farmal cub carb one time. Cleaned it well and reassembled it a couple of times and it wouldn't run right. I went through it carefully and discovered that where I bolted it on to the intake, just under the gasket - the carb was warped and no matter what, wouldn't give me a good seal. I solved that with a gooey gray gasket maker that I put on both sides of the gasket and mated the surfaces and bolted it on. I let it harden up a day before I started the tractor. Solved the problem and held up for years.
Another time my one cylinder Suzuki LS650 motocycle was flooding everytime I took it out - streaming gas out the overflow outlet. The car was in good shape, the float, etc. . I figured out that the gas tank had rust in it and a piece made it through the in-tank filter and prevented the float from closing all of the way. My solution was to add another fuel filter - JC Whitney transparent glass filter between the tank and the carb. That solved that one. When the glass filter got dirty - I unscrewed and drained it, cleaned it, reassembled it and was good to go. - I never thought rust could do that, but it did.
Goodluck.
/ New member
Well I got the W4 running. I pulled the head off of my 52 and it looked fine. It has not been running for about 25 years so I was a bit nervous. My mech friend said it should be fine. I ordered a new head gasket that cost $150cdn and took about three weeks to get here. It was made in China and went via Mexico into the US somewhere and then by pack mules to Canada. We are in the middle of our calving so spare time is limited. When I got it together it would not start. Took a look at the inline fuel filter. No gas. With fresh gas it lit right up and smoked like ****. As you can well imagine what was going through my mind. Once the smoke cleared and the carb adjusted, it sits and purrs and seems just fine. Now to put the tin on and a few other pieces and I am ready to make circles in the dirt! Just thought to let you guys know and thanks for the support.
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2014 Nissan Frontier Ext Cab Pickup Truck (A61573)
2014 Nissan...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63118)
2019 Cadillac...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
