New Member
   / New Member #1
woodchuckinthecity
Plano, IL
John Deere 650
We have a couple small tractors, a Ford 600 and a John Deere 650. I'm currently having starter problems with the Deere and I'm hoping to get some help from this forum. I've already seen quite a bit of useful information.
The tractor will not turn over with a good battery and new starter. I'm in the process of troubleshooting the start circuit and safety switches.
   / New Member #2
:welcome: to TBN...enjoy.
   / New Member #3
:welcome: Welcome to the forum!
I'm going to move your thread over to our John Deere section :)
   / New Member #4
woodchuck
:welcome: to TBN
A good place to start is to get a copy of the service tech manual, which will have schematics and the entire contents for working on your 650. Go online, or to your Deere dealer to get a copy. Worth it..
   / New Member #6
Welcome to TBN
Clean & tighten all 4 battery cable connections. Battery cable can appear good but be corroded inside of insulation.
   / New Member #7
Bench test the starter. I've gotten a bad one, new in the box (for a truck, not a tractor) Oh, WELCOME from SW MI. :welcome:
   / New Member #8
Wouldn't turn over before the new Starter either?
What test did you perform to diagnose that you needed to replace the starter??
Do you have battery voltage at the key switch? (In and Out)
What interlock switches have you tested/verified?
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2018 Bobcat T590 (A50123)
2018 Bobcat T590...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2018 FREIGHTLINER...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2011 Case 3020 30ft Flex Draper Head WITH TRAILER (A53473)
2011 Case 3020...
