   / New member #1
bassman212
richmond,ky
jd gx345
Hello everyone new member go by bassman212 have a John Deere GX 345 garden tractor already got a little information off of the side so I figured I join probably will be having more problems and need more answers so appreciate appreciate all the help I can get thank you
   / New member
I join because I'm already having trouble I GX 345 will not move forward or reverse making a grinding noise sounds like a power steering pump on a car and I was wondering if someone could tell me how much trouble it is to change the transmission drive pulley
   / New member #3
Hi and welcome to the forum! :welcome:
I'm going to move your thread over to the JD section to see if we can get you some help with that.
   / New member #7
I'm a new member too. In Chappell Hill TX. My JD3520 has had an error code 06 so I am about to check the connector for MFWD. It also just developed error code 57. Tractor won't move. Checked the seat sensor. Ideas? thanks
   / New member #8
OK, I used the forum search and found some answers. thanks for those postings!
   / New member #9
For the best response post in title of correct forum section the problem. IE in John Deere Lawn & Garden post "GX345 will not move" then describe you problem, ask your questions
   / New member #10
Welcome to the forum, hope you enjoy your time here.
Not really familiar with that particular model, but was wondering if it has a main drive belt that could be slipping??
Also, I'm guessing you play bass, am I right??
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
UNUSED LANDHERO IH-IW21 1" AIR IMPACT WRENCH (A51248)
UNUSED LANDHERO...
(4) 5 LUG WHEELS & TIRES (A51248)
(4) 5 LUG WHEELS &...
2000 HONDA RANCHER 350 ATV (A51247)
2000 HONDA RANCHER...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A53472)
GOODYEAR SET OF...
