/ New member #1
bassman212
richmond,ky
jd gx345
Hello everyone new member go by bassman212 have a John Deere GX 345 garden tractor already got a little information off of the side so I figured I join probably will be having more problems and need more answers so appreciate appreciate all the help I can get thank you
/ New member
I join because I'm already having trouble I GX 345 will not move forward or reverse making a grinding noise sounds like a power steering pump on a car and I was wondering if someone could tell me how much trouble it is to change the transmission drive pulley
/ New member #3
Hi and welcome to the forum! :welcome:
I'm going to move your thread over to the JD section to see if we can get you some help with that.
/ New member #7
I'm a new member too. In Chappell Hill TX. My JD3520 has had an error code 06 so I am about to check the connector for MFWD. It also just developed error code 57. Tractor won't move. Checked the seat sensor. Ideas? thanks
/ New member #9
For the best response post in title of correct forum section the problem. IE in John Deere Lawn & Garden post "GX345 will not move" then describe you problem, ask your questions
/ New member #10
Welcome to the forum, hope you enjoy your time here.
Not really familiar with that particular model, but was wondering if it has a main drive belt that could be slipping??
Also, I'm guessing you play bass, am I right??
/ New member
Keno. It was the drive pulley on top of the transmission . The splines had stripped out. Got it fixed and up an running.
MAXEY PORTAPOTTY VAC TRAILER (A67714)
MAXEY PORTAPOTTY...
2015 Mack GU713 T/A Day Cab Truck Tractor (A64556)
2015 Mack GU713...
2018 Ram 1500 Reefer Meal Delivery Truck (A61573)
2018 Ram 1500...
2019 Nissan Versa Sedan (A66738)
2019 Nissan Versa...
2021 CHEVROLET SILVERADO 3500HD SERVOCE TRUCK (A67714)
2021 CHEVROLET...
JOHN DEERE 5045E TRACTOR (A65057)
JOHN DEERE 5045E...
