New Member
/ New Member #1
Beechhill52
Deposit, NY
Case 311
Hello.
New member here.
Have owned a Case 311 for several years and am looking to add a somewhat bigger tractor.
Looking at the 530 series or something a bit bigger from the 60's.
Have recently purchased a 50 acre piece of old farm land with about 35 tillable.
Initially will need to get ground back in shape-mowing, fertilizing, etc. Not sure how much planting we will do.
Am in process of soil testing to determine/assess condition.
Land is a bit hilly, so looking for enough weight in tractor to handle grade.
Beechhill52
/ New Member #4
:welcome:
/ New Member
Thanks.
I have looked at a couple of Case 530s-version541 and am curious as to the year.
Serial numbers are- 8303098 and 6151359 from plates on panel along side left tin panel.
I believe the 615 is older, but neither current owner could tell me the year.
Does anyone know where I can find the year each of these was sold new?
/ New Member #6
Tractordata.com should have you awnsers.
/ New Member #7
Thanks for the welcome. I too will check out the Tractordata.com site for the age of my hoe.
Lena:)
/ New Member #9
Welcome.
/ New Member #12
Welcome to TBN. When shopping, be sure to inquire about any bolt on weights they have for the tractor.:2cents:
Woods Rotary Cutter (A63116)
Woods Rotary...
UNUSED JCT HYD AUGER (A62131)
UNUSED JCT HYD...
Patterson water pump (A59230)
Patterson water...
2012 Volkswagen Passat Passenger Car, VIN # 1VWBH7A33CC033108 (A61165)
2012 Volkswagen...
UNUSED RAYTREE RMA42 HYD AUGER (A62131)
UNUSED RAYTREE...
New/Unused CFG Industrial MH12RX Mini Excavator (A61166)
New/Unused CFG...
