Sickle Bar New member
   / New member
Well I thought I had better post an update! I am rethinking my strategy now thanks to all your input!!:mad: What I thought to be a simple plan of attack on my sapplings has evolved into more research. I will not be using my ATV for dragging a sickle mower. I AM going to look around for a small tractor capable of handling attachments. Also, I found out that there is a dealer 40 miles away who handles the "walk behind" type tractors (BCS brand). I really like this forum and the knowledgeable contributors. :)
   / New member #13
Good luck, as you have learned, there is generally no "cheap" way to do this sort of thing, just "less costly". I too am an older guy. I grew up farming and then got out of it to the point I didn't have any kind of tractor. I started by using my pickup then ATV then a well used Ford NAA.
I now have some fairly new equipment and the work is much easier. I know from experience that you don't get younger or stronger with the passage of time, so be thinking long term even if you can't swing it now. As per Soundguy older tractors are still a pretty good way to go and if you are mechanically inclined. you may never need anything else.
In the interim look at a good spray rig for weed and sapling control and maybe some controlled burns.
Good luck.
2012 Toyota Prius Hatchback (A55853)
2012 Toyota Prius...
24" EXCAVATOR BUCKET (A52707)
24" EXCAVATOR...
2016 Dodge Charger SRT Hellcat Sedan (A53424)
2016 Dodge Charger...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
23169 (A50324)
23169 (A50324)
