New Member - SA424, LX2610SU, or L2501
   / New Member - SA424, LX2610SU, or L2501 #11
Yanmar 424​
Yanmar 424 Tires
Lawn/turf front:24x8.50-14
Lawn/turf rear:36x14.00-15
Industrial front:23x8.50-12
Industrial rear:14-17.5
Dimensions
Wheelbase:63 inches
160 cm
Length:105.8 inches
268 cm
Width:54.6 inches
138 cm
Weight:1830 lbs
830 kg
Ground clearance:8.5 inches
21 cm
Front tread:37.8 inches
96 cm
Rear tread:40.5 inches
102 cm
Kubota LX2610 Tires
Standard tires (ag):Front: 7-12. Rear: 12.4-16
Industrial front:23x8.50-14
25x8.50-14
23x8.50-12 (R14)
Industrial rear:12.4-16
15-19.5
14-17.5 (R-14)
LX2610SU tires may be larger than 15-19.5.
Dimensions
Wheelbase:65.5 inches
166 cm
ROPS Length:101.8 inches
258 cm
Cab Length:103.9 inches
263 cm
Width:53.7 inches
136 cm
Height (ROPS):88.4 inches
224 cm
Height (cab):84.6 inches
214 cm
ROPS Weight:1830 lbs
830 kg
Cab Weight:2293 lbs
1040 kg
Ground clearance:14.6 inches
37 cm
   / New Member - SA424, LX2610SU, or L2501 #12
Yanmar 424​
Tractor hitch
Rear Type:1 (limited)
Control:position control
Rear lift (at 24"/610mm):1209 lbs
548 kg
This would be a deal breaker for me, possibly not for you.
Mounting and adjusting TPH implements always requires effort.
A significant portion of TPH implements will not adjust properly with a Cat 1 (limited) TPH. One can become frustrated trying to determine what will operate properly and what will not when implement shopping.
This would be a second deal breaker for me.
Yanmar 424​
Transmission
Type:hydrostatic
Gears:infinite (2-range) forward and reverse
Oil capacity:16.4 qts
15.5 L
Yanmar 424​
Tractor hitch
548 kg
This would be a second deal breaker for me:
Yanmar 424​
Transmission
Type:hydrostatic
15.5 L
Thank you, agreed. The extra $3-5k is worth being able to use and adjust a wider range of 3ph equipment - especially an auger.
Regarding the LX2610SU, do you have any feedback on options/attachments?
I spec'd one online and selected the following, anything I may not need or may need - I'm not super familiar with some of these items.
   / New Member - SA424, LX2610SU, or L2501 #14
Check this site out for the Yanmar SA424 it has all
the information you need. Yanmar also has upto a
$2,000 rebate Yanmar also has a 10 year drive train
warranty and ex-military get a discount also. I don't
know if they have a bumper to bumper warranty didn't
look. I have my YT235 very happy with it!
Go down to the bottom of forums to the Yanmar section
and ask them about the SA424 tractor what they think
about it.
willy
about it.
willy
Hi Willy,
Thanks for the tip - I really like the SA424 but am afraid it's not going to do the variety of tasks I need here and elsewhere. The YT235 is amazing but sadly, it's going to be very pricey ($30-33+k locally for one without a cab). If I lived in Oklahoma or Atlanta, one could be had for $26,5 which is slightly more than I want to spend, but my local dealers are pretty greedy.
   / New Member - SA424, LX2610SU, or L2501 #16
The SA424 works remarkable well in tight locations. It comes with a CAB as an option too. My machine is 3 generations prior the the SA424 and I love it.
The Yanmar parts support will be outstanding as the engine is a globally supported. Parts will be there even after 20 years.
Yanmar engines are in many brands. RK tractors, John Deeres, Cub Cadets, Komatsu, Yanmar Marine, various brand name gensets, etc. So parts and basic tune up items will be EZ to find.
Kubota is like John Deere. It's there way or nothing for parts. Lots of proprietary things involved with less of a global offering.
Kukje or Kukji is Korean. They have been partnered with Yanmar for over 60+ years making Yanmar parts. Kukje even makes a few of the Yanmar engines under license. Mostly the Yanmar F 3-digit Series machines. Again, parts are EZ to find for Yanmar in all parts of the globe.
thank you for this, might try the korean brands
   / New Member - SA424, LX2610SU, or L2501 #17
Nor am I, although I try to keep up with Kubota offerings.
Here is what I recommend through personal experience:
1 RATCHETING LIFT ROD KIT $128.00
(B2667)
1 TELESCOPIC LOWER LINK KIT $231.00
(B2677)
1 LOADER LX2610/LX3310 W/GRILL GUARD $4,231.00
(LA535)
1 54" QUICK ATTACH BUCKET $516.00 (SSQA?)
(B2371)
Any questions on above?
----- 0 -----​
Third function kit opens and closes grapple jaws. You do not need a grapple picking up one acre.
Unlikely you need mechanical self-leveling on one acre.
Other options you list I am not familiar with. Sorry.
   / New Member - SA424, LX2610SU, or L2501 #18
   / New Member - SA424, LX2610SU, or L2501 #19
Consider Korean tractor brands.
The most efficient way to shop for tractors is to first identify potential tractor applications, then, through consulataton, establish bare tractor weight necessary to safely accomplish your applications. Tractor dealers, experienced tractor owners and TractorByNet.com are sources for weight recommendations.
Sufficient tractor weight is more important for most tractor applications than increased tractor horsepower. Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used.
(B2667)
(B2677)
1 SWIFT TACH KIT (SSQA) WITH 1 LEVER QUICK COUPLER FOR ROPS TRACTOR $794.00
(B2386)
(LA535)
----- 0 -----​
You probably do not need mechanical self-leveling on one acre.
Thanks again Jeff, this is very helpful!
2019 Caterpillar 299D2 High Flow Compact Track Loader Skid Steer (A51691)
2019 Caterpillar...
New/Unused 75in Skid Steer Soil Conditioner (A51573)
New/Unused 75in...
John Deere 310K Backhoe (A51573)
John Deere 310K...
1999 Blaw-Knox PF 161 Paver (A52384)
1999 Blaw-Knox PF...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Kubota RTV-X1100C (A51573)
Kubota RTV-X1100C...
