New member , new tractor , naturally a problem
   / New member , new tractor , naturally a problem #11
I can't say for sure but that tractor has similar specs to my 33D.
Here is a quick maintenance guide I pulled off Messicks web site. It may give you some direction.
View attachment TC-Service.pdf
Thanks , I didnt know Messicks had that much info . I have to take a break from the tractor , my ford van blew out a spark plug , and my other service van needs a thermostat . Both went the same day . " If it aint broke , It aint mine "
Well I figured out the problem as far as the loud hydraulics and slow moving hydraulics . There was water in the hydro fluid , I drained out the fluid and replaced the hydraulic filter, and fluid and it works perfectly . I will run this for a week or 2 and then repeat the whole process .
   / New member , new tractor , naturally a problem #15
Good to hear you figured it out. Also sounds like a good idea to run it a little bit and then change it out again. Good luck.
   / New member , new tractor , naturally a problem #16
Any time buying used, first thing is change all filters and fluids.... And grease every zerk on the tractor(manual really helps find them all...). My old Kubota had like 10 total, my TC40D has like 40!
Give the battery a service/cleaning too...
I bought the user manual for the tractors I have had; worth the money...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
LOT: (6) Ratcheting Chain Binders (A59076)
LOT: (6)...
New 40ft High Cube 6 Door Container (A59000)
New 40ft High Cube...
2018 International DuraStar 4300 TMA Attenuator Truck (A55973)
2018 International...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A55973)
2015 Freightliner...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
