bbateman
Hello all,
My family and I will be moving soon from suburbia to our very small 40 acre farm. Our driveway is about 900 feet long and we're going to need something to plow it. We have enough land that we'll also need some machinery to assist in light dirt moving, hauling, and moving objects (fallen trees etc.). The driveway is currently gravel, but we're planning on paving it, haven't decided for sure yet as we're building our home next spring and it all depends on the budget. Keeping the budget in mind, what kinds of machinery should we strongly consider as a start up multi-purpose tool that we can get the most use out of for the least amount of expense. The property is as follows: 20 acres tilled and rented out, will likely remain that way. The drive bi-sects the tilled area. 5 acres of pasture which we currently rent out but will likely discontinue once the need for our (through-way) pasture to another parcel is no longer existing, and then there's 15 wooded acres which are on two hills which come together behind the location where we want to build. We plan on having about 1.5 acres of seeded lawn around the house and then the equivalent of a half acre of lawn on either side of the drive. I'm going to need a good mower, and a good utility for snow removal and other odd jobs. We're in WI where winters can be harsh so an enclosed cab with a heater.
Here's what I'm thinking, tell me if I'm on the right track: Either a Case or a Bobcat skid steer with a heated cab (all items mentioned used unless advized against it) OR a 4x4 truck with a plow blade and winch system. No idea on a mower yet but I'm starting to look into it among all the other things associated with building a home in the country.
Thanks in advance!
B
Thanks in advance!
B
