new member john deere 2555
   / new member john deere 2555 #1
brandon5110
gainesville, tx
john deere 2555
Hello forum. New member to forum. John deere 2555. Have hydralic issues.
   / new member john deere 2555 #2
Hi. Welcome. Lots of people here know hydraulics. What is the issue?
Ok thanks for the reply. Ill start from the begining. I bought tractor from someone who didnt take care of it very well and only used fel. Everything worked at first. Hyd pump was loud sometimes. Ok i was bailing and knocked the tranny filter housing off. Notice who ever messed with before didnt not install properly. So put new filter in and fluid and pto would not work under load. Used brush hog after and started working again. Nxt time i bailed, i turn 4 bails out then started to slip. My shifter handle had come out on inside. So i remove plate to fix and the 2 ports that come up for pto, the seals where falling apart. Put new seals in, pto was stronger but would not turn brush hog well. So started looking for somethen else. But everything else worked. I kept using tractor for loader. Then started noticing resistance on the steering when I lower the loader then my lift started getting weaker and then I lost all hydraulic but if i move control on one of the romotes to certain spot i will get pressure back. Have not put gauge on it yet. I have a service manual but not getting much info from it.
20711 (A50323)
20711 (A50323)
2005 Isuzu NPR Venco VC516 Landscape Dump Truck (A53422)
2005 Isuzu NPR...
UNUSED LANDHONOR LHR-DFP10 DSL FUEL TRANSFER PUMP (A54757)
UNUSED LANDHONOR...
2018 KENWORTH T680 SLEEPER (A54607)
2018 KENWORTH T680...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND68FDGH1824 (A54865)
2015 Freightliner...
