New Member and new owner of 1968 Ford 4110 LCG
   / New Member and new owner of 1968 Ford 4110 LCG #1
4110LCG
Twinfalls Idaho
ford 4110 LCG
Hey guys I just purchased a 1968 Ford LCG for $1500 runs and drives pretty good. I think it has the 201 gasser engine question is I live in southern Idaho and weather is extreme from well over 100 to -20 below. I have been running straight 30w in the tractor but when I started it up to plow the snow this last storm it seemed as if the oil was to thick and it knocked for a moment or 2 on start up and starter was having trouble engagin flywheel only happens when very cold outside above 40 no issues at all. Would it be safe to run a split weight 10w30 or 10w40 hours on engine are unknown runs great no smoke starts up nicely when temps are above 40??? Also what type of hydralic fluid or what type of oil do I use in the rear end is this conected to the hydralic system for 3 point ( when its cold the blade will barely move up and down at temps below 20)
   / New Member and new owner of 1968 Ford 4110 LCG #2
Hi. Welcome. Congrats on the tractor.
You can run the multi grade oils. the 10w means it will flow like 10 weight but is still a 30 weight oil.
Synthetics work great in the cold. In the hydraulics too.
I engage the PTO during warm up to help warm the hyd. oil faster.
awesome great advice never thought of engaging the pto to help warm her up. I will switch out the old hydro fluid to a synthetic but will that interfear with the wet shoe brake system??? My new Holland dealer doesnt have any info on the old girl because it is an industrial model and they are an AG dealer only so i am forced to search out info on the internet. !!!
   / New Member and new owner of 1968 Ford 4110 LCG #4
Welcome to the forum!
:welcome:
I'm going to move this thread on over to the Ford section to see if we can get you some more advice.
   / New Member and new owner of 1968 Ford 4110 LCG #5
Synthetic will work fine for the brakes. May improve them too. I think you will be happy with the synthetic.
   / New Member and new owner of 1968 Ford 4110 LCG #6
20 below? I'd be running 5w40 full syn!...
I thought about running 5w40 that is what I have on hand due to my truck using that grade. I am a little Leary about running a synthetic in an older motor i believe they are a much higher detergent oil. I am going to switch from a straight weight to multi-grade but stay clear of synthetics soon as it warms up I will go back to a straight weight for summer. If it was a fresh motor I totally would switch to synthetic but I have no clue about the history of this old girl.
   / New Member and new owner of 1968 Ford 4110 LCG #8
That 68 should be fine on a syn oil.
Keeping a straight weight oil in her is a tad brutal :)
2020 JOHN DEERE 6145M LOT NUMBER 79 (A53084)
2020 JOHN DEERE...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
2025 New/Unused Wolverine 36in Hydraulic Backhoe Excavator Thumb (A51573)
2025 New/Unused...
STORAGE FEES (A52577)
