New Member 20acres NE Oklahoma & buying more
   / New Member 20acres NE Oklahoma & buying more #1
PaulNEOK
NE Oklahoma
none
Hello.
I am considering Kubota/Kioti/Branson for mowing/fencework/pallet lift/snow/and some backhoe work
I plan on storing the tractor and implements on a dedicated trailer to move between three properties.
My thoughts are 35HP is a minimum, but I don't need a monster tractor either.
Some work will be keeping brush cleared in an orchard and vineyard, so maneuverability is important. Does this call for a HST?:us-oklahoma:
   / New Member 20acres NE Oklahoma & buying more #2
Welcome to the forum.. HST.. HydroStatic Transmission.. does make it a lot easier.. Lou
   / New Member 20acres NE Oklahoma & buying more #3
:welcome:
   / New Member 20acres NE Oklahoma & buying more #5
Welcome from the same area.
Ken
   / New Member 20acres NE Oklahoma & buying more #7
   / New Member 20acres NE Oklahoma & buying more #8
Welcome to TBN :)
I moved your thread to the Buying/Pricing/Comparisons forum.
   / New Member 20acres NE Oklahoma & buying more #9
Welcome to TBN--join the fun:D
HST? Why not--makes operation simpler than gears.
Kubota makes nice stuff--my first tractor was a new 2005 Kubota B7510HST. My neighbor has a Kubota L4400 which would be a nice fit for your needs.
Mahindra makes good stuff also. They have nice backhoes that fit their equipment.
Good luck.
   / New Member 20acres NE Oklahoma & buying more #10
The HST v gear is a never ending debate here with strong proponents on both sides. I run and like both, but give the HST the edge in maneuverability and ease of use over a long day in the seat. For new tractor users, I believe the advantages are even more significant.
I like Kubota, but the other brands make good tractors as well and I imagine a 35-40 HP or so will serve you well.
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2000 FORD E350 CUTAWAY BOX TRUCK (A54313)
2000 FORD E350...
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A54814)
2012 Crane Carrier...
